How Does the Normal Force on a Rock in Water Differ with Varying Water Levels?
In summary, the normal force exerted on the rock by the bottom of the tank is equal to half of its weight, as the buoyant force is equal to half of the gravitational force on the object. The amount of water pushing down on the object is not necessary in determining the normal force. Archimedes' principle states that any object immersed in a fluid is buoyed up by a force equal to the weight of the fluid displaced by the object. The normal force may change as the force due to pressure from the fluid above changes, but it will always be equal to half the weight of the object.
phrygian
80
A rock of mass M with a density twice that of water is sitting on the bottom of an aquarium tank filled with water. The normal force exerted on the rock by the bottom of the tank is?
The answer is Mg/2, I understand how to arrive at that by subtracting the buoyant force which is equal to mg from the gravitational force on the object which is 2mg. but shouldn't the normal force on the object be different when there are different amounts of water pushing down on it? Since the amount of water is not given shouldn't the correct answer be "impossible to determine from the information given?
Hi phrygian. Are you familiar with the Archeimedes' principal? Let's not talk about "amount" of something. Let's give everything a specific, measurable quantity such as "volume" or "mass". Archimedes' principal simply states that any object, wholly or partly immersed in a fluid, is buoyed up by a force equal to the weight of the fluid displaced by the object.
So the rock displaces some volume of water which has a given weight.
Does that help?
I understand that but if I make a free body diagram for the rock wouldn't the forces be normal force + bouyant force - gravitational force - force due to pressure from the fluid above = 0 ? So doesn't the normal force change as the force due to pressure from the fluid above changes when there are different amounts of fluid above?
A free body diagram of the forces on the object in the water would consist of the forces down (weight of object) minus the forces up (integrate pressure over the area). This can be simplifed if we imagine a cubical volume. Forces on the sides cancel out. Force on top equals pressure times area. Force on bottom equals pressure times area. Use Bernoulli's equation to determine pressure. The force up (difference in pressure times area) minus the force down (weight) equals the weight of the fluid, which is exactly what Archimedes' principal tells us.
1. What is pressure?
Pressure is the amount of force exerted per unit area. It is typically measured in units of Pascals (Pa) or pounds per square inch (psi). Pressure can be applied by a solid, liquid, or gas and is a fundamental concept in physics and engineering.
2. How is pressure related to normal force?
The normal force is the force that a surface exerts on an object that is in contact with it. When an object is at rest on a surface, the normal force is equal and opposite to the force of gravity acting on the object. The normal force and pressure are directly related, as pressure is equal to the force per unit area. So, the normal force can be thought of as the pressure exerted by a surface on an object.
3. What factors affect pressure and normal force?
The main factor that affects pressure and normal force is the amount of force applied to the surface. The greater the force, the higher the pressure and normal force will be. Additionally, the surface area over which the force is applied also affects pressure and normal force. The smaller the surface area, the higher the pressure and normal force will be.
4. How does pressure and normal force impact objects?
Pressure and normal force can have various impacts on objects, depending on the situation. In some cases, high pressure and normal force can cause objects to compress or deform. In others, these forces may be necessary to keep objects in place or prevent them from sinking. Pressure and normal force are also important in understanding the behavior of fluids, such as how they flow and exert forces on objects within them.
5. What are some examples of pressure and normal force in everyday life?
We encounter pressure and normal force in many aspects of our daily lives. For example, the pressure of the air in a car tire keeps it inflated and able to support the weight of the vehicle. Normal force is also present when we sit on a chair, as the chair exerts a force on us to counteract the force of gravity. In fluids, pressure and normal force can be seen in the way water pushes on a diver's body or how air molecules exert pressure on our skin.
