What is the Minimum Value of h for Fluid to Enter a Vein?
In summary, the minimum value of h that allows the fluid to enter the vein is 0.581 m. This takes into account the atmospheric pressure at the top of the reservoir.
Dougggggg
155
Pressure in a fluid, need help, test tomorrow!
There is a needle in a patient's arm and then a tube that leads to a reservoir of fluid ([tex]\rho[/tex]=1050 kg/m3) located at h height above the arm. The reservior is open to air and the gauge pressure inside the vein is 5980 Pa, what is the minimum value of h that allows the fluid to enter the vein?
I keep getting this answer and it is off completely from the answer to the book.
(p1-p2)/((rho)g)
Latex and me don't work well together but I'm sure you get the point.
h=9.26 m
Book answer is .581 and doesn't have a unit even listed with it.
EDIT:Nevermind, I didn't know that gauge pressure was the pressure with respect to atmospheric pressure. Close thread.
Hello,
First of all, great job attempting to solve this problem! It's important to understand that gauge pressure is the pressure measured relative to atmospheric pressure. This means that the pressure inside the vein is 5980 Pa greater than the atmospheric pressure. In order to find the minimum value of h, we need to take into account the pressure at the top of the reservoir, which is also atmospheric pressure.
So, the equation you used is correct, but we need to take into account the pressure at the top of the reservoir as well. This means that our equation becomes:
(p1 - p2)/((rho)g) = h + atmospheric pressure - atmospheric pressure
Since atmospheric pressure is the same on both sides of the equation, we can cancel it out and our equation becomes:
Now, we can plug in the values given in the problem:
(5980 Pa - 0 Pa)/(1050 kg/m^3 * 9.8 m/s^2) = h
Solving for h, we get:
h = 0.581 m
This is the minimum value of h that allows the fluid to enter the vein. It is possible that the book answer is in meters as well, but it's always good to double check the units. Keep up the good work and good luck on your test tomorrow! Let me know if you have any other questions.
1. What is pressure in a fluid?
Pressure in a fluid refers to the force exerted by the fluid on its surroundings. It is typically measured in units of force per unit area, such as pascals or pounds per square inch.
2. How is pressure in a fluid calculated?
The pressure in a fluid can be calculated using the formula P = F/A, where P is pressure, F is force, and A is the area on which the force is acting. This formula is known as Pascal's principle.
3. What factors affect pressure in a fluid?
The pressure in a fluid can be affected by the density of the fluid, the depth or height of the fluid, and the acceleration due to gravity. Additionally, external forces, such as objects placed in the fluid, can also impact the pressure.
4. How is pressure in a fluid measured?
Pressure in a fluid is typically measured using instruments such as a barometer or manometer. These devices use the height or displacement of a fluid column to determine the pressure.
5. What are some real-world applications of pressure in a fluid?
Some common examples of pressure in a fluid include hydraulic systems, such as car brakes and elevators, as well as weather phenomena like air pressure systems. Pressure in a fluid is also important in understanding the behavior of liquids and gases in pipes, pumps, and other industrial applications.
13K
14K
9K
