Pressure inside a thermos
  1. Oct 6, 2008 #1
    A well insulated 2 liter thermos bottle contains 500 ml of boiling liquid Nitrogen, and the remainder of the thermos has Nitrogen gas at 1 atmosphere in equilibrium with the liquid. You drop a 200 gram piece of iron at 25 degrees Celsius inside and seal the cap. After 5 seconds, what is the pressure inside the thermos?
    2. Relevant equations
    [tex]\rho[/tex] liquid nitrogen = 810 kg/m3
    [tex]\rho[/tex] iron = 7.87 g/cm3
    PV = NkT
    I think that I need more equations to solve the problem, but I don't know what they are.
    3. The attempt at a solution
    V total = 2 L = 0.002 m3
    V liquid nitrogen = 500 ml = 500 * 10-3 L = 0.5 L = 0.0005 m3
    before dropping the iron in: V nitrogen gas = 0.002 m3 - 0.0005 m3 = 0.0015 m3
    V iron: [tex]\rho[/tex] = mV [tex]\rightarrow[/tex] 7.87 g/cm3 = 200g(V) [tex]\rightarrow[/tex] V = 0.03935 cm3 = 0.0003935 m3
    after dropping the iron in: V nitrogen gas = 0.0015 m3 - 0.0003935 m3 = 0.0011065 m3
    Tinitial of liquid nitrogen = boiling point at 1 atm = 77.2 K
    Tinitial of iron = 25 degrees Celsius = 298 K
    Pinitial of liquid nitrogen = Pinitial of nitrogen gas = 1 atm = 0.013 * 105 Pa
    [tex]\Delta[/tex]t = 5 seconds
    Pfinal = ?
    I just don't know which equation to use.
  3. Oct 6, 2008 #2
    You need to work out how much heat energy the iron gives up when cooled (assume final T of iron = LN2)
    Assume this energy goes into boiling extra LN2.
    Work out how much extra N2 this generates.
    Then it's just gas laws for the pressure.
    The 5 seconds is tricky, are you sure about that part? Unless you are expected to calcualte heat diffusion rate from the iron it's irrelevant.
  4. Oct 6, 2008 #3
    thanks, i will give that a try and then reply again when i come up with something. i think the 5 seconds is just enough for relaxation time so that we don't have to worry about anything during the relaxation time.
