Why is the pressure inside a bubble greater than the pressure outside?
In summary, the difference in pressure between the inside and outside of a bubble is derived by minimizing the Helmholtz energy and can be found using the equation dF = - p_inside * dV1 - p_outside * dV2 + σdS, where S is the bubble surface area. This equation takes into account the different forces at play and the positive term for surface tension represents the work required to expand the surface. This is similar to blowing up a balloon, where the elasticity of the material resists expansion and work must be done to overcome it. In bubbles, the attracting forces between molecules tend to contract the surface, while in drops, the surface tends to form a sphere to minimize surface area.
aaaa202
1,169
As you may know the pressure inside a bubble of is greater than the pressure outside due to the surface tension. Now in my book the difference is derived by minimizing the Helmholtz energy such that:
This can then be used to find the correct equation for the difference in pressure. But intuitively I don't understand why. To find the pressure one must balance the different forces and is the above equation doing that? Also why is the last term positive? I.e. the negative signs come from the fact that p_inside is directed in the opposite direction as dV1 and similarly for the second term. When the surface expands does it then do positive work on the system?
You are asking some good questions! This one ended up in the homework part of PF, where they want you to use a template. Never mind.
If p_inside>p_outside and all the d's are pointing in the same direction, ##\sigma## is positive, which is nice.
Compare it with blowing up a balloon: the elasticity of the material resists expansion; you have to do work to overcome that. And yes, when expanding, the surface has to push away the surrounding air, which requires work (p_outside * delta V). Inside pressure has to do more work: stretching the surface and pushing away the outside air.
In bubbles the attracting forces between the molecules (van der Waals forces) tend to contract the surface.
In drops you have the same thing: they tend to form spheres because that minimizes surface area.
1. What causes pressure inside of a bubble?
The pressure inside of a bubble is caused by the gases trapped within it. As the gas molecules move around and collide with the walls of the bubble, they create a force that pushes against the surface, creating pressure.
2. How does the size of a bubble affect its internal pressure?
The smaller the bubble, the higher the pressure inside of it. This is because the gas molecules are more densely packed in a smaller space, resulting in more frequent and forceful collisions with the bubble's walls.
3. Can the pressure inside of a bubble change?
Yes, the pressure inside of a bubble can change. It can increase if the bubble is exposed to external forces, such as heat or shaking, that cause the gas molecules to move faster and collide with more force. It can also decrease if the bubble is able to expand, allowing the gas molecules to spread out and collide with the walls less frequently.
4. What happens to a bubble when the pressure inside is greater than the surrounding air pressure?
If the pressure inside a bubble becomes greater than the surrounding air pressure, the bubble will expand. This is because the force of the gas molecules pushing against the walls of the bubble is greater than the force of the air pushing back on the outside.
5. Is there a limit to how much pressure can build up inside of a bubble?
Yes, there is a limit to how much pressure can build up inside of a bubble. This limit is determined by the strength of the bubble's surface tension and the maximum amount of gas that can fit inside the bubble. If the pressure becomes too high, the bubble will burst, releasing the excess gas and reducing the pressure.
