Pressure of a bubble in Liquid
In summary, the problem involves determining the pressure inside a bubble located 4.0 m below the surface of a liquid ethyl alcohol in a rigid container. Using the equation P = P(nought) + (density)(gravity)(height), with the density of alcohol being .806 x 10^3 and the air pressure above the liquid being 1.1 atm, a calculation results in a pressure of 338.22, which may not be the correct answer. Converting the given air pressure to Pa may help in solving the problem.
Air is trapped above liquid ethyl alcohol in a rigid container. If the air pressure above the liquid is 1.1 atm, determine the pressure inside a bubble 4.0 m below the surface of the liquid.
P= P(nought) + (density)(gravity)(height)
density of alcohol .806 x 10^3
Pnought would be the 1.1 atm
P= 1.1 + (806 kg/m^3)(9.8 m/s^2)(4 m)
= 31596
That isn't the right answer, so I'm very confused. Do I need to change atmospheres to kPas? Is that density correct? Am i even using the right equation?
I would definitely convert the 1.1 atm to Pa to see if that's your problem. Your units aren't consistent the way they are.
It isn't [tex]P_0*\rho gh[/tex]
Its [tex]P_0 + \rho gh[/tex]
davidatwayne said:
P= P(nought) x (density)(gravity)(height)
= 338.22
You've got two versions of the equation written down here. The one you used in your calculation is the right one, but I can't figure out how you got the 338.22 even if it is wrong.
Suggested for: Pressure of a bubble in Liquid
