Pressure of a diver is 10X
  • Thread starter colonel
colonel
I want to find when the pressure of a diver is 10X that when she is on the surface of the ocean. I know that at the surface, the diver experiences a pressure of 1 atm. But how do I go about finding the pressure under water? Do I have to consider teh partial pressure of water?
Answers and Replies
russ_watters
Mentor
21,942
8,979
Its a piece of cake really. Air pressure is due to the weight of a column of air pushing down on you. Water pressure works the same way (though a little easier since water is essentially incompressible). So all you need to do is calculate the weight of that column of water at a specific depth. Its the volume times the density. (the weight density of water is 62.4 lb/ft^3)
Andre
4,509
74
But also the density of water is 1,000 kg/litre by definition. And 1 Atm = a column of 76 cm of Hg (Torricelli) with a density of 13,6 kg/l. Now, how high would that column be if the Hg was to be replaced by water?
Suggested for: Pressure of a diver is 10X
  • Last Post
