What is the minimum pressure in an evacuated tank half-filled with 40°C water?
In summary, the minimum pressure that can be expected in the space above the water will be the equilibrium vapor pressure of water at 40 degrees. This is because when all the gas is evacuated, the remaining water will evaporate into the head space, creating a pure water vapor pressure that will equilibrate to the equilibrium vapor pressure at 40 degrees.
giacomh
36
A tank half-filled with 40°C water is to be evacuated. What is the minimum pressure that can be expected in the space above the water?
Vp water @ 40 degrees = 3.38
I would have just subtracted the vapor pressure from the atmospheric pressure, but no temperature is given in this problem. I don't know how to take into account the fact that it's a half-empty tank.
Thanks!
Been a long time since I did this so perhaps wait for a better answer. Meanwhile ..
http://www.engineeringtoolbox.com/humid-air-ideal-gas-d_677.html
the total pressure exerted by a mixture of gases is the sum of the partial pressures of the individual gases
So perhaps apply the Ideal Gas law PV=nKT assuming constant temperature to the dry air. (eg volume doubles so pressure halves).
Not sure what to do about the water vapour? Do you need to subtract the vapour pressure before halving as above?
But what if some water vapour remains? Perhaps you need add it back again or calculate the reduced vapour pressure to add back?
What do they mean by "evacuated"? Just the liquid water drained or the air and water vapour removed as well? Not sure there is enough info to answer the problem?
If you evacuate all the gas from above the water, enough water will evaporate into the head space such that the pressure will equilibrate to the equilibrium vapor pressure of water at 40 degrees. It only takes a very small amount of evaporation to do this. The gas in the head space will be pure water vapor.
What is the pressure inside an evacuated tank?
The pressure inside an evacuated tank is 0 Pa (absolute pressure) or -14.7 psi (gauge pressure) at sea level.
How is the pressure of an evacuated tank calculated?
The pressure of an evacuated tank can be calculated using the ideal gas law: P = (nRT)/V, where P is the pressure, n is the number of moles of gas, R is the gas constant, T is the temperature in Kelvin, and V is the volume of the tank.
What happens to the pressure inside an evacuated tank as the volume increases?
As the volume of an evacuated tank increases, the pressure inside decreases. This is because the number of gas molecules remains constant, but they are spread out over a larger area, resulting in a lower pressure.
Can the pressure inside an evacuated tank ever be negative?
No, the pressure inside an evacuated tank cannot be negative. Negative pressure does not exist in physical systems, and the pressure inside an evacuated tank is already at its lowest possible value (0 Pa).
Why is it important to maintain a vacuum in an evacuated tank?
Maintaining a vacuum in an evacuated tank is important because it ensures that there is no external pressure acting on the tank's contents. This is necessary for certain scientific experiments and industrial processes that require a controlled and isolated environment.
