Pressure of fluid on submarine
In summary, the pressure of fluid on a submarine can vary depending on its depth, with an average of 14.7 psi or 101.3 kPa at sea level. This pressure can affect the buoyancy, stability, and structural integrity of the submarine, which is why it is designed with strong and thick hulls. The shape and internal pressurization also play a role in withstanding pressure. If the pressure exceeds the structural strength or there is a malfunction, it can be dangerous, leading to collapse or implosion. As the submarine ascends or descends, the pressure of fluid changes, which is essential for maintaining buoyancy and stability.
queen2008
a miniature sub is lowered to a depth of 8.5 m in sea water of density 1030 kg/m^3. The interior of the sub is maintained at a pressure fo 1.00 atm. Find the net force that must be withstood by a 1.5 diameter hatch which leads to the insisde.
F= PA P= p + density X gravity X Hight
Change in Pressure = 0 so P= 1030 X 9.8 X8.5
Hint, there is also one atmosphere of pressure pushing down on top of the water, and one atmosphere of pressure pushing out from the inside of the sub.
1. What is the pressure of fluid on a submarine?
The pressure of fluid on a submarine can vary depending on the depth at which the submarine is submerged. However, on average, the pressure of fluid at sea level is 14.7 pounds per square inch (psi) or 101.3 kilopascals (kPa). For every 33 feet of depth, the pressure of fluid increases by 14.7 psi or 101.3 kPa.
2. How does the pressure of fluid affect a submarine?
The pressure of fluid on a submarine can affect its buoyancy, stability, and structural integrity. As the submarine descends to deeper depths, the pressure of fluid increases, causing the submarine to become more negatively buoyant. This means that the submarine will tend to sink deeper into the water. The pressure of fluid can also put stress on the submarine's hull, which is designed to withstand high pressures. If the pressure of fluid exceeds the structural strength of the hull, it can lead to leaks or even collapse of the submarine.
3. How do submarines withstand the high pressure of fluid?
Submarines are designed to withstand high pressures by using strong and thick hulls made of steel or titanium. These materials are able to withstand the pressure of fluid at various depths. The shape of the submarine also plays a key role in withstanding pressure. The rounded shape of a submarine allows the pressure to be distributed evenly, reducing the stress on the hull. Additionally, the internal compartments of a submarine are pressurized, allowing the crew to live and work comfortably without feeling the effects of the external pressure of fluid.
4. Can the pressure of fluid on a submarine become dangerous?
Yes, the pressure of fluid on a submarine can become dangerous if it exceeds the structural strength of the submarine or if there is a malfunction in the pressurization system. In extreme cases, the pressure of fluid can cause the submarine to implode, leading to loss of life and the submarine itself. This is why it is crucial for submarines to undergo rigorous testing and maintenance to ensure their structural integrity and safety.
5. How does the pressure of fluid change when a submarine ascends or descends?
As a submarine descends, the pressure of fluid increases, and as it ascends, the pressure decreases. This is due to the changing depth and therefore, the changing amount of water above the submarine. For example, at a depth of 100 feet, the pressure of fluid is twice as much as it is at the surface. This change in pressure is crucial for submarines to maintain their buoyancy and stability while navigating through different depths of water.
