1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Pressure Problem
  1. Jun 30, 2011 #1
    Pressure Problem!!
    Oxygen at pressures much greater
    than 1 atm is toxic to lung cells. By weight, what ratio of
    helium gas (He) to oxygen gas (O2 ) must be used by a
    scuba diver who is to descend to an ocean depth of
    50.0 m?
    2. Relevant equations
    3. The attempt at a solution
    I first found the total pressure at that depth (note they didn't explicity give me rho_seawater, but I assumed):
    P_50m = pgh = (1020kg/m^3)g(50m) = 4.93atm. Now here's where I get stuck. I assume that since O2 can only be 1atm, thus Helium must take up 4.93atm - 1atm = 3.93atm. Then I put these back into their own P = pgh, and solve for their 'p':
    1atm =(p_O2)gh -> p_O2 = 206.7kg/m^3. Doing the same thing for p_He, I get 812.5kg/m^3. Then I simply take the ratio, and get phe/po2 = 3.93. The answer says 0.625. Any ideas??
    Ari
  3. Jun 30, 2011 #2
    Andrew Mason
    Re: Pressure Problem!!
    What is the pressure at 0 m depth? Add the additional pressure at 50m. to this to get the absolute pressure.
    In order to determine the proportion of He to O2 by weight, you must determine first the molar proportions. It is the molar proportions that determine pressure: In the ideal gas law: PV=nRT so [itex]P \propto n[/itex]
    Work that out and then determine what the relative weight would be.
    I get a slightly different answer: assuming that water has a density of 1000 kg/m^3.
    AM
Similar Discussions: Pressure Problem
  1. Pressure problems. (Replies: 9)
  2. Problem with pressure (Replies: 6)
  3. Pressure problem (Replies: 5)
  4. Pressure problem. (Replies: 3)
  5. Pressure problem? (Replies: 1)
Loading...
