Prime Numbers (Eratosthenes)
  1. Feb 26, 2017 #1
    SGJ
    Mod note: added code tags
    Code (C):
    using System;
    using System.Collections.Generic;
    using System.Linq;
    using System.Text;
    namespace ConsoleApplication1
      class Program
        static void Main(string[] args)
           List<int> number = new List<int>(1000); // int list for 1000 numbers
           for(int i = 0; i < 1000; i++) // for loop that populates the numbers array
              number.Add (i + 1); // the first position in the array will equal 1 rather than zero
           for (int i = 2; i <= 32; i++) // This is the first loop that will run the square root of 1000 times
              for (int j = 2; j < 32; j++) // Nested for loop that will run for the square root of 1000 times
                   number.Remove(j * i); // every muptiple will be removed leaving only odd numbers
              foreach (int numbers in number)
                 Console.Write(" " + number.Count); // writes the numbers still left in the list
          Console.ReadKey(); // Keeps program open
  3. Feb 26, 2017 #2
    SGJ
    So here is my problem (this is my first time using lists and this site so bear with me) whenever I try to run this it prints 970 and will repeat that number hundreds of times. I want it to print 1, 3, 5, 7, 11, 13, 17.... ect. Please help urgent C#.
  4. Feb 26, 2017 #3
    jack action
    number.Count should return the number of items in the list. So you are printing '970' ... 970 times!
    Try Console.Write(" " + numbers) instead.
  5. Feb 26, 2017 #4
    SGJ
    I tried that and it printed 1-1000 several hundred times.
    I then tried just printing "number" but it printed "systems collection generic" another thousand or so times.
  6. Feb 26, 2017 #5
    jack action
    I'm not really good with C#, but this is a good resource where I found the following:
    Code (C):
    number.ForEach(Print);
    private static void Print(string s)
        Console.Write(" " + s);
    There is also a simple method:
    Code (C):
    Console.Write(number.ToString());
  7. Feb 26, 2017 #6
    My very first observation (being a C# programmer) is that, since you've included System.LINQ, you might want to consider fully using it by changing
    Code (Text):
    to
    Code (Text):
    List<int> number = Enumerable.Range(1,1000).ToList();
  8. Feb 26, 2017 #7
    SGJ
    Thank you for that!
    Do you have any solution as to why I am getting large repetitions of numbers starting at around 970?
  9. Feb 26, 2017 #8
    QuantumQuest
    The error lies in your for loops. Take a careful look again. As a hint, don't print out numbers until you have removed what you need first.
  10. Feb 26, 2017 #9
    Mark44
    Staff: Mentor
    Your algorithm is incorrect. After removing values from your list that are the products of numbers of the form a * b, where both a and b are in {2..32}, your list ends up with numbers that aren't prime. The first one I see starts at 74 (= 2 * 37). Also present are is and b = 82, 86, 94, 106, and a slew of others. Instead of removing numbers a * b with a and b in {2, ..., 32}, go through the entire list and remove multiples of 2, then multiples of 3, and so on, up to 32.
  11. Feb 26, 2017 #10
    Mark44
    Staff: Mentor
    BTW, your foreach loop is nested within the outer for loop, which causes it to run 31 times (printing out your list that number of times). It should NOT be nested within that outer for loop.
    Code (C):
         } // <---- Added by Mark44
           Console.Write(" " + number[numbers]); // writes the numbers still left in the list
  12. Feb 26, 2017 #11
    QuantumQuest
    Also, as Mark44 points out your algorithm is incorrect. You will see it if you first correct the error according to my hint: the resulting numbers are not all primes.
  13. Feb 26, 2017 #12
    SGJ
    using System;
    using System.Linq;
    using System.Text;
    class Program
    for (int i = 0; i < 1000; i++) // for loop that populates the numbers array
    number.Add(i + 1); // the first position in the array will equal 1 rather than zero
    for (int i = 2; i < 1000; i++) // This is the first loop that will run the square root of 1000 times
    for (int j = 2; j < 1000; j++) // Nested for loop that will run for the square root of 1000 times
    if (i * j < 1000)
    So this is as far as I got. Thanks to your help, the multiples stopped and i do have some primes but some of them are missing such as 13, all the primes in the 20's etc. The (" " + number[numbers]) line gives it a Out of range error.
  14. Feb 26, 2017 #13
    QuantumQuest
    I'll give a hint in a different direction. Try to fill your array with all multiples of 2 and 3. To do this, you need two nested loops, the first going from 2 to 1000 and the second might begin with the double of the variable in the first loop, but the tricky part is how to increment it in order to fill all the multiples. I leave it to you to tinker with it, till you figure it out. Then, you can print out whatever is not included in your array, using another loop. What will be these numbers you will print out?
  15. Feb 26, 2017 #14
    Mark44
    Staff: Mentor
    @SGJ, please use code tags when you post code. Not doing so loses any indentation you have.
    [code=c]using System;
    using System.Linq;
    using System.Text;
    // etc. [/code]
  16. Feb 26, 2017 #15
    SGJ
    Code (C):
    using System;
    using System.Linq;
    using System.Text;
    class Program
    if (i * j < 1000)
    // etc.
  17. Feb 26, 2017 #16
    SGJ
    sorry im new to this, I posted the code in the comment above.
  18. Feb 26, 2017 #17
    Mark44
    Staff: Mentor
    Do you have a question about what you posted in #14?
  19. Feb 26, 2017 #18
    SGJ
    yes, why do I get a range error at Console.WriteLine(" " + number[numbers])
  20. Feb 26, 2017 #19
    SGJ
    Code (C):
    using System;
    using System.Linq;
    using System.Text;
      class Program
           int[] check = new int[1000]; // another array for the mathematics.
           // for (int i = 0; i < 1000; i++) // for loop that populates the numbers array
              // number.Add(i + 1); // the first position in the array will equal 1 rather than zero
           for (int i = 0; i < 1000; i++) // This is the first loop that will run the square root of 1000 times
                check[j] = i + 1; // populates check
                if(check[ i ] % check[j] == 1) // If the remainder of check position i and check position j is one (odd number test)
                  number.Add(i); // The number is added to number
    so I decided to take a completely different route. Now I get a domain/range error at the line (check[ i] % check[j] ==1)
    I ONLY USED 1 AS A TEST.
  21. Feb 26, 2017 #20
    Mark44
    Staff: Mentor
    I'm still looking at your code, but in the meantime, a couple of tips:
    1. Don't put any spaces in the starting code tag. It has to be [code=c], not [code = c]. The extra spaces breaks things.
    2. An array index of i (as in check[i]) is treated as a starting Italic tag, and you end up garbled code, as the browser "eats up" Italics tags, bold tags, etc. The workaround is to add a space before the i, as in check[ i].
  22. Feb 27, 2017 #21
    What are you even trying to do? I can't quite see where are you going with this. Try using some real comments, not repeating something everyone can see. E.g. replace "This loop runs 1000 times" with "this array holds...whatever".
    The contents of the "check" array are always check[j]=i+1. Why do you need such an array?
    Haven't we fixed this already?
    You should only ask if you are desperate and can't find an error. Posting the first, half baked attempt here is not going to teach you anything.
  23. Feb 27, 2017 #22
    Mark44
    Staff: Mentor
    Because numbers is too large to be a valid index for your number list.
    I would also recommend giving your variables better names. numbers is OK for the list, but IMO list would be better. On the other hand, number is so close to numbers lexicographically that it would be easy for someone (including yourself) to get confused about which one does what.
    Since your code is C++, you are presumably using Visual Studio, which has a very nice debugger. Use it to find the values of your variables when your code is running.
    Same reason as above. When you get the range error, check the values of i and j.
    Also, as already mentioned, there really is no need for the check list.
Have something to add?
Draft saved Draft deleted
Loading...
