Principle of Least Action in Electrostatics
In summary, Feynman's lecture on the principle of least action discusses how electrostatics can be described by minimizing or maximizing a specific integral. He demonstrates this concept by using it to approximate the capacitance of a coaxial line. Later, he suggests using this method for other shapes by adjusting unknown parameters like alpha to obtain accurate numerical results for difficult problems. However, the application of this method becomes challenging for more complex problems and may require conformal mapping or other methods. It is also unclear how to choose the best approximate field and parameters for a given problem. Further explanation and guidance on this topic would be beneficial.
nassboy
39
In Feynman's lecture on the principle of least action, he show that you can describe electrostatics by saying that a certain integral is a minimum or maximum. He states the integral, and goes on to show how it can be used to approximate the capacitance of a coaxial line. I've been able to follow his argument and use a similar technique to solve the parallel plate capacitor.
Later Feynman states that, "For any other shape, you can guess an approximate field with some unknown parameters like alpha and adjust them to get a minimum. You will get excellent numerical results for otherwise intractable problems."
I can't seem to apply his method to anything but the simplest of cases. For example, coming up with an approximate field that meets complicated boundary conditions in 2D seems impossible...leaving conformal mapping as the only usable method of solving such problems. I also tried solving another problem that Feynman solves in a more traditional manner, "Colloidal particles in an electrolyte." using the least action principle...but what approximate field should I choose besides a polynomial?
I'm having trouble understanding what kind of field is best used in these cases. Can someone explain how the principle of least action can be used for more complex problems? Is there a general method of constructing an approximate field for a given problem? How do I choose the parameters such as alpha? Any help would be greatly appreciated!
The principle of least action in electrostatics is a powerful tool in solving complex problems and obtaining numerical results. However, it is important to keep in mind that it is not a one-size-fits-all approach and may not be applicable to all cases.
In the case of complex boundary conditions in 2D, it may be challenging to come up with an approximate field that meets all the conditions and still yields a minimum or maximum value for the integral. In such cases, other methods like conformal mapping may be more suitable.
When it comes to choosing an approximate field for a problem, it is important to consider the physical properties and boundary conditions of the system. A polynomial may work for some cases, but for others, a different functional form may be more appropriate. It may also be helpful to use a combination of different functions to approximate the field.
Overall, the principle of least action in electrostatics is a valuable tool, but it is important to consider its limitations and use it in conjunction with other methods for more complex problems. it is always important to explore and experiment with different techniques to find the best approach for a particular problem.
Related to Principle of Least Action in Electrostatics
1. What is the Principle of Least Action in Electrostatics?
The Principle of Least Action in Electrostatics is a fundamental concept in classical mechanics and electrostatics that states that a system will always follow the path of least resistance or energy in order to reach equilibrium. This principle is based on the idea that nature tends to minimize energy and maximize efficiency.
2. How does the Principle of Least Action apply to electrostatic systems?
In electrostatic systems, the Principle of Least Action states that charged particles will always move in such a way that the total electric potential energy is minimized. This means that they will move along the path that requires the least amount of work to reach a state of equilibrium.
3. What are the implications of the Principle of Least Action in electrostatics?
The implications of the Principle of Least Action in electrostatics are far-reaching. It allows us to predict the behavior of charged particles in electric fields and understand the fundamental principles governing electrostatic systems. It also helps us to design efficient and effective electrical devices and systems.
4. How is the Principle of Least Action related to the laws of conservation of energy and momentum?
The Principle of Least Action is closely related to the laws of conservation of energy and momentum. In fact, it can be derived from these laws. The principle states that the total energy of a system is conserved and that the system will always move in a way that minimizes the energy required to reach equilibrium.
5. Are there any real-world applications of the Principle of Least Action in electrostatics?
Yes, there are many real-world applications of the Principle of Least Action in electrostatics. For example, it is used in the design of electrical circuits, electric motors, and generators. It is also used in the field of optics to understand the behavior of light in different media and to design optical devices such as lenses and mirrors.
  • Mechanics
  • Quantum Physics
  • STEM Academic Advising
