Principle of virtual work invention
In summary, Virtual Work is a principle that was invented to solve problems in statics. It is a way of calculating the amount of work that is done by virtual forces instead of real forces. When applied to dynamical systems, virtual work can be used to solve equilibrium problems.
srchandran
i want to throughly understand the principle of virtual work. why this principle was invented?
"sum of work done by forces is zero". such a definition is very vague for me. can anyone explain?
I will try explain you, but I sorry for my bad english.
You know that Work is Force * "desplazamiento" W=F*d
In Static problem the displaicement d are 0, then you can imagine virtual Force to solve some problems knowing that finally the virtual work will be zero.
The example I've seen is a ball rolling down a frictionless surface. Since there is no friction, the work done by the surface is zero. That simplifies the math if you're doing Langrangian mechanics.
If there is no friction, what force or couple acts to cause the ball to rotate?
In any event this is an example of real work, not virtual work.
It would be very helpful if sr chandran would tell us in what context he is studying VW. The answer can be very mathematical or more practical depending upon the field of study.
I has used VW in Static because displaicement are little. I teach this method for solve structures like trusses ("cerchas" in spanish). You suppose that has solve (forces and elongations of bars) a very complex structure (Structure 0) and you need to know what is the displaicement of one nude of the structure. You can imagine a virtual force in the nude and calculate all the structure only with this virtual force (Structure 1 virtual). After this, you can obtain the displaicement of the node with Structure 0 and Structure 1 using VW.
Whit VW and lineal equations of compatibility of movements you obtain lineal equations of equilibrium. Then VW conected static lineal equations of compatibilty of displaicement with equilibirum.
Yes, the ball will slide on the surface and not rotate. The force of constraint is normal to the surface. There is no friction to overcome. The virtual work done by the forces of constraint is zero. The constraints are always defined to ensure this.
In statics, since the total force is zero, the virtual work done by the total force must also be zero. This allows solutions like Rafa has described. Clearly the displacements must be virtual since nothing really moves in statics.
I can't reconcile my picture of virtual work with your description.
When you do a virtual work calculation you introduce either imaginary displacements or imaginary forces and calculate the 'virtual work' carried out by either the real forces acting over these imaginary displacements or the virtual work carried out by the imaginary forces over the real displacements in the system.
The virtual work equation does not say the virtual work is zero it says
The sum of the virtual external work = the sum of the internal virtual work
Which is a very different thing.
Studiot, your picture of virtual work is the consequence of my explication of VW.
In every nude of a roof truss, the equilibrium tell us that the sum of forces will be 0. You can multiply this equilibrium for a vector, in particular for a displacement vector (in this case you have a VW=0)
You can move every nude of the truss virtualy withou work. Then you have a sum over all nudes of the truss and other sumatory over the equilibirum forces in every nude, if you operate you can separate in two sumatories of works. And the results are:
The sum of the virtual external work = the sum of the internal virtual work.
If I have a blackboard may be I can explain better.
Don`t hesitate in correcting my english. I try to improve my wiriting english.
Hello Rafa, I am not disagreeing with anything you have said, my comments were directed at presbyope's posts.
I just think it is important to point out that virtual work is not another energy theorem.
The 'work' calculated is neither real work nor complementary work so the true energy theorems of Castigliano the reciprocal theorem and so on cannot be used in conjunction with VW.
Some authors call VW the unit load or unit force method, but it can be much more comprehensive than simply applying a unit force in the direction of interest to obtain the deflection of a structure.
In fact VW can also be applied to dynamical systems as well as static ones.
Studiot,
Thanks
I never used the VW applied to dynamical systems, but I agree that virtual work is not another energy theorem.
Srchandram...did you understand?
1. What is the Principle of Virtual Work Invention?
The Principle of Virtual Work Invention is a fundamental concept in mechanics that states the equilibrium of a system can be determined by considering the virtual work done by all the external and internal forces acting on the system. It was first developed by Bernoulli in the 18th century and has since been applied in various fields of engineering and physics.
2. How does the Principle of Virtual Work Invention work?
The principle works by considering a hypothetical displacement, known as a virtual displacement, of a system in equilibrium. This displacement does not actually occur, but it allows us to calculate the virtual work done by the forces acting on the system. If the virtual work done by all these forces is zero, then the system is in equilibrium.
3. What are the applications of the Principle of Virtual Work Invention?
The principle has many practical applications in engineering, such as in the design of structures and machines. It is also used in the analysis of trusses, frames, and other mechanical systems. Additionally, it is applied in fields like robotics, where it helps in the control and optimization of robot movements.
4. What are the benefits of using the Principle of Virtual Work Invention?
The principle offers a more efficient and systematic approach to solving mechanical problems. It reduces the complexity of calculations and allows for easier visualization of forces and their effects on a system. It also provides a theoretical basis for many engineering methods and concepts, making it an essential tool for engineers.
5. Are there any limitations to the Principle of Virtual Work Invention?
While the principle is a powerful tool in mechanics, it does have some limitations. It can only be applied to systems in static equilibrium and does not account for dynamic effects like inertia and acceleration. It also assumes that the virtual displacements are small and that all forces are conservative, which may not always be the case in real-world scenarios.
  • Mechanical Engineering
  • Mechanics
  • Quantum Physics
