Probability & Time: Is There a Connection?
In summary, the conversation revolves around the idea of whether there is a fundamental relationship between the probability of occurrence of an event and the flow of time. The main question is whether time is a perception of a probability distribution of events in our universe, where more probable events happen earlier and less probable ones happen in the future. However, examples are given to show that this concept does not hold true, as even in simple cases of probabilistic and deterministic events, the idea of more probable events happening earlier does not always hold true. The conversation also touches on the concept of an isolated space and its influence on time and probability. Overall, it is concluded that probability is simply something that occurs over time, rather than causing or being time flow itself.
jocarren
Hi, I'm new in the forums, actually I registered to ask this question (I have these wild, often ridiculous ideas).
Is there a fundamental relationship betwen the probability of ocurrence of an event and the flow of time around that event?
I mean, imagine an isolated space where some type of events can occur randomly, if we asume that the most probable events will occur earlier than the less probable ones, can we relate the passage of time with that probability distribution?
Put in simple terms: is time a perception of a probability distribution of events in our universe? (More probable events happened before and less probable ones will happen in the future).
Well, you said it yourself. It is a ridiculous idea!
I don't think so. If we put a block of uranium-238 and a clock in this space, and a block of uranium-235 and a clock in another space, there would be no difference in the passage of time between the two even though their decay rates are very different.
That is a good example. Even for a block of a single isotope all atoms are equally likely to decay, but they don’t all decay at the same time.
Thanks for your answer ;)
Maybe I misused the term "isolated space", what I mean this space is the only space in this universe, there is no other space ouside it (of it is not observable). An observer inside that place will percieve the passage of time is only through the decay of this isotope (using your example).
Other way to see at it is in a universal scale, in the entire Universe, let's say the probability of some quantum field fluctuation to occur is very, very low, would you say is the first thing that happens in the early Universe? or that it will happen some time after?
Is time the perception of the ocurrence of events that are less and less probable?(in a fundamental level).
You could try watching this:
http://www.cornell.edu/video/richard-feynman-messenger-lecture-5-distinction-past-future
We have already answered this: No. This concept of time does not even work for the simplest probabilistic case (decay of unstable particles).
It also does not work for simple deterministic clocks. The day 5 Jan 2018 is less probable than month Feb 2018 but it comes first. And from a broader perspective an unwound clock is more likely than a wound clock but the unwound clock comes last.
Sorry, but the only part that isn't quite ridiculous is this:
Certainly. That's what probability means: a block of U235 decays at a specific rate. And a block of U238 occurs at a slower specific rate.
But you're trying to flip the idea over backwards into having event probability causing (or being) time flow instead of simply being something that occurs over time. It's like suggesting that if there is more traffic, time passes slower.
Stop right there. For probabilities, you should say "more often", not "earlier". That makes a big difference. It means that no matter how likely or unlikely something is, it (or something similar with the same probability) has already happened and will happen again. So the direction of time is not related to probabilities, as far as our definitions and understanding of probabilities are concerned.
Likes Dale
Nothing changes. The uranium-238 would decay with a half life of about 4.5 billion years. The uranium-235 would decay with a half life of about 700 million years.
That's not how probability works. Even an event with an extraordinarily low probability of occurring could occur prior to an event with an extremely high probability of occurring. It is possible that 100 trillion atoms of uranium-238 all decay before any atoms of a block of uranium-232 decay, despite the latter's half life being about 8 orders of magnitude shorter. It is quite impossible to predict with perfect accuracy when a random event will occur, no matter how likely or unlikely.
Only if the laws of physics are fundamentally different than how we currently understand them.
Thank you everyone for your answers, sorry if I hurt your eyes with this kind of questions :)
1. What is the relationship between probability and time?
The relationship between probability and time is a complex and debated topic in the scientific community. Some theories suggest that time is a fundamental aspect of probability, as it represents the progression of events and the likelihood of certain outcomes occurring. Others argue that time and probability are separate concepts, with time being a dimension through which probabilities can be measured. Ultimately, the connection between probability and time is an ongoing area of research and is not yet fully understood.
2. How does probability play a role in predicting future events?
Probability is a key factor in predicting future events, as it allows us to quantify the likelihood of different outcomes occurring. By assigning probabilities to various outcomes, we can make informed predictions and decisions based on the likelihood of certain events happening. However, it is important to note that probability is not a guarantee and cannot accurately predict all future events.
3. Can probability be used to explain the concept of "time travel"?
The concept of time travel is highly theoretical and has not been scientifically proven, so it is difficult to say whether or not probability can be used to explain it. Some theories suggest that time travel is possible through manipulating probabilities and creating alternate timelines, but this is purely speculation and has not been substantiated by scientific evidence.
4. Are there any real-world applications for the connection between probability and time?
Yes, there are many real-world applications for the connection between probability and time. For example, probability is used in weather forecasting to predict the likelihood of certain weather events occurring in a specific time frame. It is also used in financial markets to make investment decisions based on the probability of certain outcomes. Understanding the relationship between probability and time can also help us make better decisions in our daily lives.
5. How does the concept of "time dilation" impact probability?
Time dilation, a phenomenon predicted by Einstein's theory of relativity, occurs when time appears to pass at a different rate for objects moving at different speeds. It has been observed in experiments involving fast-moving particles and has also been confirmed through GPS technology. This concept can impact probability by altering the perception of time and changing the likelihood of certain events occurring. However, the exact impact of time dilation on probability is still a subject of study and debate.
  • Other Physics Topics
  • Quantum Interpretations and Foundations
