Probability Density Current
  • Thread starter elemis
Calculate the probability current density vector [itex]\vec{j}[/itex]for the wave function [itex]\psi = Ae^{-(wt-kx)}[/itex].
From my very poor and beginner's understanding of probability density current it is :
[itex]\frac{d(\psi \psi^{*})}{dt}=\frac{i\hbar}{2m}[\frac{d\psi}{dx}\psi^{*}-\frac{d\psi^{*}}{dx}\psi][/itex]
By applying the RHS of the above equation :
[itex]\frac{i\hbar}{2m}[-A^{2}ikxe^{-i(ωt-kx)}e^{i(ωt-kx)}-A^{2}ikxe^{i(ωt-kx)}e^{-i(ωt-kx)}][/itex]
This gives :
[itex]\frac{-2iA^{2}ik\hbar}{2m}=\frac{k \hbar A^{2}}{m}[/itex]
This is not the correct answer. :( What have I done wrong ?
Answers and Replies
TSny
3,416
This equation isn't correct. But the right hand side does represent the current density.
This gives :
This looks correct to me for the magnitude of the current density.
Maybe you need to express your answer as a vector.
Or, maybe you are supposed to allow A to be a complex number. If so, then A2 in your answer would need to be modified.
201
There seems to be a sign mistake - I think.
201
No, letting A be complex doesn't change anything.
TSny
3,416
The probability current must be real. If A is complex (i.e., nonzero imaginary part), then A2 is also complex.
What is the correct form of the LHS of the equation ? I'm assuming the RHS is completely correct ?
I realised that [itex]\hbar k[/itex] = mv = p can be substituted into the last step of my workings to obtain j = A2v which is the correct answer.
Where exactly ?
TSny
3,416
The left hand side represents the rate of change of the probability current at some point. This should equal the negative of the divergence of the probability current vector at that point. In one dimension the gradient is just the derivative with respect to x. So, to make the equation correct, you would need to apply -d/dx to the RHS.
Good.
201
No, A2 is not necessarily equal to A x A. It is a fairly common notation to define A2 = AA* which is real.
TSny
3,416
That seems confusing to me. There are times when we really do want the square of a complex number z (i.e., z2) rather than the square of the magnitude (i.e., |z|2 = z*z).
But, anyway, at least we agree on the substance of the answer to the question.
Related Threads on Probability Density Current
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
