Proving the Validity of a Bernoulli Distribution Probability Function
In summary, a Probability Density Function (PDF) is a mathematical function used to describe the probability of a continuous random variable falling within a certain range of values. It is different from a Cumulative Distribution Function (CDF) in that it shows the probability of a single outcome, while a CDF shows the probability of a range of outcomes. The area under a PDF curve represents the probability of the random variable falling within a certain range of values, and it is always equal to 1. A PDF is commonly used in data analysis to understand the distribution of data and make predictions. It assumes that the data is continuous, the total area under the curve is equal to 1, and the probability of any particular outcome is between 0 and
pyro_peewee
I'm just curious as to how to prove that a Bernoulli distribution probability function is valid (ie. that it is indeed a probability distribution function). I have a hunch that all we do is add up all of the probabilities associated to every x value, but I'm not sure. Can someone confirm this? Can someone show me how?
Best place to start is writing down the definitions
What is a Probability Density Function (PDF)?
A Probability Density Function (PDF) is a mathematical function that describes the probability of a continuous random variable falling within a certain range of values. It is used to analyze and understand the distribution of data.
How is a PDF different from a Cumulative Distribution Function (CDF)?
A PDF gives the probability of a random variable taking on a specific value, while a CDF gives the probability of the random variable being less than or equal to a certain value. In other words, a PDF shows the probability of a single outcome, while a CDF shows the probability of a range of outcomes.
What is the area under a PDF curve?
The area under a PDF curve represents the probability of the random variable falling within a certain range of values. The total area under the curve is always equal to 1, as the probability of any outcome occurring is always 100%.
How is a PDF used in data analysis?
A PDF is used in data analysis to understand the distribution of a dataset and to make predictions about future outcomes. It can also be used to compare different datasets and identify any similarities or differences in their distributions.
What are the assumptions of a Probability Density Function?
The assumptions of a Probability Density Function are that the data is continuous, the total area under the curve is equal to 1, and the probability of any particular outcome is between 0 and 1. Additionally, the PDF assumes that the data is normally distributed, meaning it follows a bell-shaped curve.
  • Poll
