Finding Density Functions for Randomly Chosen Points in a Unit Square
In summary, the conversation discusses finding the density function for the sum and product of coordinates of a point chosen at random inside a unit square. The interval for the first part is between 0 and 2, and the final step in calculating the density function is unknown. The use of geometry, specifically drawing lines of constant x+y, may aid in solving the problem.
Fuquan22
A point Q is chosen at random inside the unit square. What is the density function of the sum of the coordinates of point Q? What is the density function of the product of the coordinates of the point Q? Use geometry to find these densities.
P(a < X < b) = Integral (a,b) of f(x)dx
I know that the interval for the first part has to be between 0 and 2, but I don't know f(x)
choosing a point at random from unit square is in effect equivalent to choosing 2 independent uniform random variables, say X & Y, on the interval [0,1].
Then you want to find the density function for Z = X + Y
Yes but how do i go about finding that density function? I just don't know the final step to calculating a density function.
It says use geometry. So does drawing lines of constant x+y help you solve it?
1. What is a Probability Density Function (PDF)?
A Probability Density Function (PDF) is a mathematical function that describes the probability distribution of a continuous random variable. It assigns a density or relative likelihood to each possible value of the random variable.
2. How is a PDF different from a Probability Mass Function (PMF)?
A Probability Mass Function (PMF) is used to describe the probability distribution of a discrete random variable, while a PDF is used for continuous random variables. A PMF assigns a probability to each possible value, while a PDF assigns a density or relative likelihood to each possible value.
3. How is a PDF used in statistics?
A PDF is used in statistics to calculate the probability of a continuous random variable falling within a specific range of values. It is also used to determine the mean, variance, and other statistical properties of a random variable.
4. What is the relationship between a PDF and a Cumulative Distribution Function (CDF)?
A Cumulative Distribution Function (CDF) is the integral of a PDF and represents the probability that a random variable is less than or equal to a given value. In other words, the CDF is the sum of all the probabilities from the PDF up to a specific value.
5. How is the area under a PDF curve related to probability?
The area under a PDF curve represents the probability of a continuous random variable falling within a certain range of values. The total area under the curve is equal to 1, meaning the probability of the random variable taking on any possible value is 1.
