Probability of multiples
  1. Jun 27, 2014 #1
    adjacent
    An integer is chosen random from the first 100 positive integers. What is the probability that the integer is divisible by 6 or 8?
    2. Relevant equations
    NaN
    3. The attempt at a solution
    The answer is 24/100 if I ignore one of the Multiples of 6 AND 8,which occurs 4 times in 100
    The answer is 28/100 if I include the numbers which occur twice
    What is correct here?
  3. Jun 27, 2014 #2
    HallsofIvy
    Staff Emeritus
    What do you mean by "ignore" and "count"? You certainly cannot "ignore" multiples of 24 (smallest number divisible by both 6 and 8) you just don't want to count them twice. 24/100 is correct. 6 divides into 100 16 times. 8 divides into 100 12 times. 24 divides into 100 4 times. There are 16+ 12- 4= 24 numbers less than 100 which are divisible by 6 or 8 or both.
  4. Jun 27, 2014 #3
    adjacent
    Oh, thanks.
    I have another question too.
    The answer is 233168 according to them. But I think this is wrong.
    This is the code which was used to get this answer:
    Code (Text):
    int result = 0;
    for (int i = 1; i < 1000; i++) {
        if (((i % 3) == 0) || ((i % 5) == 0)) {
            result += i;
    Obviously,if a number is a multiple of both 3 and 5, then we should add it to the result twice. However, this code does not do that. That means this is wrong.
    The actual answer should be:
    1000/5=200. The question asks numbers below 1000, so it should be 200-5=195. ##\to##195 multiples of 5 is below 1000.
    1000/3=333.333... so 333 multiples of 3 is below 1000.
    Then we should sum the arithmetic sequences of multiples of 3 and 5:
    $$\frac{n}{2}(a+l)$$
    $$\frac{333}{2}(3+999)+ \frac{195}{2}(5+995)=264333$$
    The answer is ##264333##
    Who is right? Me or project euler?
  5. Jun 27, 2014 #4
    If a number is a multiple of both 3 and 5, it gets added to the result twice. So you should subtract the numbers which are a multiple of ##\text{lcm}(3,5)=15## because those numbers will be added twice in the sum and you get an erroneous result.
    ##199## multiples of ##5##.
    Replace ##195## with ##199## and remember to subtract the sum of numbers which are a multiple of ##15##.
  6. Jun 27, 2014 #5
    adjacent
    Oh, thanks for that 199.
    I still do not understand. The question asks to Find the sum of all the multiples of 3 or 5 below 1000.
    Why should we not add the multiples of 15 simply because it occurs twice?
  7. Jun 27, 2014 #6
    When you add the multiples of 3, you also add the multiples of 15, right?
    When you add the multiples of 5, you again add the multiples of 15. So now there are two instances of the same number getting added to the required sum. Do you see now?
  8. Jun 27, 2014 #7
    adjacent
    Oh , I see that the "OR" in the question is an exclusive or. But how do we determine it from the question?
  9. Jun 27, 2014 #8
    Isn't that obvious? We need to count the numbers which are either a multiple of 3 or 5. So if the question asked about the numbers less than 20, then the required set of numbers would be 3,5,6,9,10,12,15,18 instead of 3,5,6,9,10,12,15,15,18.
  10. Jun 28, 2014 #9
    haruspex
    2016 Award
    No, it's inclusive. If it were exclusive you would not count multiples of 15 at all. It is inclusive, so you count multiples of 15 once. In neither case would you count them twice.
  11. Jun 28, 2014 #10
    adjacent
    Why? This is an example of inclusive or
    This becomes true even if p and q comes twice. :confused:
      File size:
      945 bytes
      99
  12. Jun 28, 2014 #11
    Orodruin
    Staff Emeritus
    P or Q is 1 if P and Q is 1. You are treating it as if it was 2.
  13. Jun 28, 2014 #12
    Orodruin
    Staff Emeritus
    Well, in logic terms what you are doing is first summing over P=1 and then adding the sum over Q=1. This is not the same as summing over (P or Q). The sum over (P or Q) is exactly what is in the code in #3.
  14. Jun 28, 2014 #13
    adjacent
    Ok, I think I understand now. Thanks guys
Have something to add?
Draft saved Draft deleted
Similar Discussions: Probability of multiples
  1. Vector Multiplication (Replies: 2)
  2. Longhand Multiplication (Replies: 11)
  3. Matrix multiplication (Replies: 2)
  4. Vector multiplication (Replies: 6)
Loading...
