Probability of type I error
  • Thread starter safina
Given that X is a uniform random variable on the interval [tex](0, \theta)[/tex], we might test [tex]Ho: \theta = 1[/tex] versus the alternative [tex]H_{1}: \theta = 2[/tex] by taking a sample of 2 observations of X and rejecting Ho if [tex]\bar{X} > 0.99[/tex]. Compute [tex]\alpha[/tex]
2. The attempt at a solution
[tex]\alpha[/tex] = P[type I error]
= P[rejecting Ho| Ho is true]
= P[[tex]\bar{X} > 0.99 given that \theta = 1][/tex]
I just know that if X is a uniform random variable, it has a pdf:
[tex]f\left(x; a, b\right) = \frac{1}{b - a}I_{[a, b]}(x)[/tex]
Kindly help me what to do next.
Answers and Replies
LCKurtz
Insights Author
767
So, under H0, what is the joint pdf of X1 and X2? You didn't state it but I'm guessing the two observations are independent. Once you have that you can calculate α directly.
the joint pdf of X[tex]_{1}[/tex] and X[tex]_{2}[/tex] is [tex]\frac{1}{\theta}[/tex] [tex]\frac{1}{\theta}[/tex] = [tex]\frac{1}{\theta^{2}}[/tex]
But I still don't get how is it related in getting [tex]\alpha[/tex]
LCKurtz
Insights Author
767
But under H0, θ = 1, so your joint probability is 1 on the unit square. Do you know how to calculate a probability when you know the joint pdf? You just need to calculate the probability
[tex]P\left(\frac {X_1+X_2}{2} >.99\right)[/tex]
I really am confused how to calculate this probability.
Also I think there is no table for uniform distribution.
LCKurtz
Insights Author
767
You don't need a table. This problem can be done without calculus, but the normal way to calculate a probability is with an integral. Have you had calculus?
Generally, if X and Y have joint pdf f(x,y) and A is a subset of the sample space
[tex]P(A) = \iint_A f(x,y)\,dxdy[/tex]
In your case
[tex]A =\left\{ (x_1,x_2):\frac{x_1+x_2}{2} > .99 \right\}[/tex]
In your case
[tex]P\left[\frac{X_{1}+X_{2}}{2} > 0.99\right][/tex] = [tex]\int^{1}_{0}\int^{0.98}_{0} 1 dx_{1}dx_{2}[/tex] = 0.98
Is this right?
If I double integrate the joint pdf with when X1 goes from 0 to 1 and X2 goes from 0 to 1, I got [tex]P\left[\frac{X_{1}+X_{2}}{2} > 0.99\right][/tex] = 1.
I think it is not right because it is too high to be a value of [tex]\alpha[/tex]
LCKurtz
Insights Author
767
Is this right?
You are correct thinking that isn't right. You need to draw a picture of the unit square and shade the portion of it where (x1+x2)/2 > .99. Then integrate over that region. Hint: It isn't a rectangle, which your attempt is, having constant limits.
Related Threads on Probability of type I error
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
