I Probability - z value
  • Thread starter rexxii
Summary
Probability - z value - stats issue
Hi,
I'm working on a question now where I need to calculate the z value. which I have been able to but I'm calculating a value off the normal distribution that is on the left-hand side of the normal distribution curve and it needs to on the right side. As the value i'm looking into is higher than the mean!
I cannot figure out how I would turn this around. its only one independent event theres no replacement or other variables.
the question is:
A cable manufacturer tests the cables it produces to find the breaking load. Over many years this has been assumed to be normally distributed with a mean of 6000 newtons and standard deviation of 155 newtons. Calculate the probability that a single cable chosen at random, will have a breaking load greater than 6200 N.
Z = 6200 -6000 /155 = 1.29
Then ive written a probability statement (P z>1.290) = P z>1.290)
read from the stats tables that it could be 0.9015.
Said the breaking load is 90.15%
I know this is incorrect please can you advise
The probability that a randomly selected cable will have a breaking load greater breaking load than 6200 Newtons is 90%.
4,222
Summary: Probability - z value - stats issue
Hi,
the question is:
You're reading the table wrong. The table is giving you P(z < 1.290) = 0.9015. So what would be the probability you want, P(z > 1.290)?
So i need to read from the RHS side? as it is above the mean? Would i still select that number or a different one of the table?
32,487
4,222
P(z < 1.290) = .9015, from the table. The number .9015 represents the area under the standard normal curve between ##z = -\infty## and z = 1.290. What is the total area under the curve? What's the area under the curve between z = 1.290 and ##z = +\infty##?
1.29 - 1 = 0.29 above the mean?
32,487
4,222
No, and this doesn't make any sense -- you're mixing two unrelated things there: the z-value and the probability associated with a certain z-value.
Have you seen a graph of the standard normal curve? In the standard normal distribution, half of the area under the curve is to the left of the mean at z = 0, and the other half is to the right. What's the total area under the curve? How much of the area under the curve lies to the left of z = 1.29? How much of the area lies to the right of z = 1.29?
It would be a good idea to read the section in your textbook that has this problem. There's quite a bit you don't understand.
Want to reply to this thread?
"Probability - z value" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
