Probably really easy
  • Thread starter rbanerjee23
In summary, a 280 g block is resting on a plane at a 30° angle above the horizontal. The coefficient of kinetic friction between the block and the plane is 0.1. It is attached to a 210 g block hanging freely by a string over a frictionless and massless pulley. To find the second block's speed when it has fallen 30 cm, you must first find the tension in the string caused by the motion of the first block.
rbanerjee23
A block of mass m1 = 280 g is at rest on a plane that makes an angle = 30° above the horizontal (Figure 5-41). The coefficient of kinetic friction between the block and the plane is µk = 0.1. The block is attached to a second block of mass m2 = 210 g that hangs freely by a string that passes over a frictionless and massless pulley. When the second block has fallen 30 cm, its speed is?
How do I solve this
How do I solve this
Hint: find the tension in the string caused by the motion of block 1.
problem?
To solve this problem, we can use the principles of Newton's laws of motion and the equations of motion to calculate the speed of the second block after it has fallen 30 cm. First, we need to draw a free body diagram for each block and apply the equations of motion to determine the acceleration of the system.
For the first block, we have the force of gravity acting downwards (mg) and the normal force of the plane acting upwards. The force of friction, which is equal to µk times the normal force, acts in the opposite direction of motion. Since the block is at rest, the net force in the horizontal direction is zero. In the vertical direction, the net force is equal to the weight of the block (mg) minus the normal force (N), which is equal to the mass times the acceleration (ma). Therefore, we can write the following equations:
ΣF = 0 (horizontal direction)
ΣF = ma (vertical direction)
Solving for the normal force, we get N = mgcosθ, where θ is the angle of the plane. Substituting this into the vertical equation, we get:
mg - mgcosθ = ma
a = g(1-cosθ)
Now, for the second block, we have the force of gravity acting downwards (m2g) and the tension in the string acting upwards. The tension in the string is equal to the weight of the first block (m1g) plus the force of friction between the two blocks (µkm1g). Using the same equations as before, we can write:
ΣF = T - m2g = m2a (vertical direction)
Substituting the value of acceleration from the first block, we get:
T - m2g = m2g(1-cosθ)
Now, we can solve for the tension in the string, T, by substituting the values of m1, m2, and θ. Once we have the tension, we can use the equations of motion to calculate the speed of the second block after it has fallen 30 cm. The final equation would be:
v^2 = u^2 + 2as
Where v is the final velocity, u is the initial velocity (which is zero in this case), a is the acceleration, and s is the distance (30 cm in this case). Solving for v, we get:
v =
1. What is the meaning of "Probably really easy"?
"Probably really easy" is a phrase that implies something is expected to be simple or uncomplicated.
2. Is "Probably really easy" a scientific term?
No, "Probably really easy" is not a scientific term. It is a colloquial phrase used in everyday language.
3. Can "Probably really easy" be used in a scientific context?
While it is not a scientific term, "Probably really easy" can be used in a scientific context if it accurately describes the simplicity of a concept or task.
4. Are there any synonyms for "Probably really easy"?
Yes, some synonyms for "Probably really easy" include "likely simple," "probably uncomplicated," or "presumably straightforward."
5. Is "Probably really easy" a subjective or objective statement?
"Probably really easy" is a subjective statement as it is based on personal perception and expectation. What one person considers "really easy" may not be the same for another person.
