Problem about mean curvature
  • Thread starter raopeng
raopeng
86
Prove that the only surfaces with zero mean curvature are either planes or hyperbolic curves with the equation: [itex]y = \frac{\cosh (ax+b)}{a}[/itex] rotating alone the x axis.
I made an attempt by devoting the equation of the surface as r = r(x) then take this back to the definition of mean curvature which ended up with a very complicated differential equation. Then I worked out the expression of mean curvature using Vieta's formula only to find myself facing a even more complex differential equation again. However there must be an easy way to prove the statement.
Thanks!
Answers and Replies
raopeng
86
Eh solved it myself. Let be [itex]x = u (r)[/itex] substitute this in the Mean Curvature expression [itex](1 + \frac{\partial u}{\partial y}^{2})u_{zz} - 2 u_{x}u_{y}u_{xy} + (1 + \frac{\partial u}{\partial z}^{2})u_{yy}[/itex]
Integrate the expression obtained so one can find out the expression of the surface is to be {itex}\frac {e^{az} + e^{-az}}{2a}{\itex}
raopeng
86
Eh solved it myself. Let be [itex]x = u (r)[/itex] substitute this in the Mean Curvature expression [itex](1 + (\frac{\partial u}{\partial y})^{2})u_{zz} - 2 u_{x}u_{y}u_{xy} + (1 + \frac{\partial u}{\partial z}^{2})u_{yy}[/itex]
Integrate the expression obtained so one can find out the expression of the surface is to be [itex]\frac {e^{az} + e^{-az}}{2a}[/itex]
Suggested for: Problem about mean curvature
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
