Prove Difference of Squares of Odd #s is Multiple of 8
  • Thread starter Trail_Builder
In summary, the conversation discusses how to prove that the difference between the squares of any two odd numbers is a multiple of eight. The solution involves showing that (r^2 - r - n^2 + n) is even, which can be done by reasoning that if both r and n are even, then each of r^2-n^2 and n-r must differ by a multiple of two, making their sum a multiple of eight. This suffices as proof for a multiple of eight.
Trail_Builder
149
hi, i have nearly done this problem but made a mistake somewhere, hope you can help, thnx
Prove that the difference between the equares of any two odd numbers is a multiple of 8.
n/a
where r is an integer, and n is an integer:
(2r-1)^2 - (2n-1)^2
4r^2 - 4r + 1 - 4n^2 + 4n - 1
4r^2 - 4r - 4n^2 + 4n
4(r^2 - r - n^2 + n)
now, that would show it to be multiple of 4, does this then suffice for proof for a multiple of 8? (8 a multiple of 4)
thnx, just need a quick confirmation of this..
cheers
You can reason this way:
1) If both r and n are even, then each of r^2-n^2 and n-r must differ by a multiple of two, so their sum does too. The overall quantity is thus a multiple of eight.
You can do the other two cases...
Or you can just show r^2-r is even for ANY r (so clearly so is n^2-n).
soz, i don't mean to sound super noobish, but i don't quite understand how that works :S soz
cna't someone please elabourate? thnx
if r an n are both even , then r^2 and n^2 are even.
that means r^2-n^2 is even, now since r and n are even then r-n is even.
so (r^2 - r - n^2 + n) is even.
o rite, i see that, but where does it go from there?
"now, that would show it to be multiple of 4, does this then suffice for proof for a multiple of 8? (8 a multiple of 4)"
Just for illustration purposes, 12 is a multiple of 4, because 4(3) = 12
Does that mean 12 is a multiple of 8?
o yeh, duh! stupid me, lol, i was getting in a muddle
1. What is the formula for the difference of squares of odd numbers?
The formula for the difference of squares of odd numbers is (2n+1)^2 - (2n-1)^2, where n is any integer.
2. How do you prove that the difference of squares of odd numbers is a multiple of 8?
To prove that the difference of squares of odd numbers is a multiple of 8, we can use mathematical induction. First, we show that the formula holds true for n=1. Then, assuming it holds true for n=k, we can show that it also holds true for n=k+1. This will prove that the formula works for all odd numbers and therefore the difference of squares of odd numbers is always a multiple of 8.
3. What is the significance of proving that the difference of squares of odd numbers is a multiple of 8?
Proving that the difference of squares of odd numbers is a multiple of 8 has several applications in number theory and algebra. It can be used to simplify and factorize algebraic expressions, as well as to solve certain types of equations and problems involving odd numbers.
4. Can this formula be extended to other types of numbers?
No, this formula specifically applies to odd numbers. However, there are similar formulas for finding the difference of squares of even numbers and the difference of squares of any two consecutive numbers.
5. How can this formula be used in real-world applications?
The formula for the difference of squares of odd numbers can be used in various real-world scenarios, such as in computer programming, cryptography, and data encryption. It can also be applied in physics and engineering, particularly in calculating the difference between two quantities or values.
