Problem for my programming languages class
  1. Aug 23, 2004 #1
    Hi I have a problem for my programming languages class =\
    It goes like this We need to make a program that checks the sintaxis for monkeys... =d but well you see their Alphabet is {a, b, d, ^, ;} in where ^ means an empty space.
    The grammar is represented in a metalanguage
    <sentence> ::= <word>;|<sentence>^<word>
    <word> ::= <syllable>|<syllable><word><syllable>
    <syllable> ::= <explotion>|<explotion><high>|a<explotion>|a<high>
    <high> ::= b|d
    the program must answer things like, which of the following is the fake monkey?
    Monkey1: ba^ababadada^bad^dabbada;
    Monkey2: abdabaadab^ada;
    Monkey3: dab^ad^abaadad^badadbaad;
    Anyway I've done some work on it but, and I've made the program this way:
    import java.io.*;
    import java.lang.*;
    class Sentence{
    private String line; // String de Entrada.
    private boolean ValidDigits; // Son los Digitos de Entrada Validos? (a, b, d, ^, ;)
    private int location; // Posicion actual en el Arreglo de Caracteres.
    private int nmroSilabas; // Numero de Silabas en Palabra.
    private char[] Palabra; // Arreglo que toma un fragmento del String;
    public Oracion (String s)
    linea = s;
    digValidos = true;
    loc = 0;
    Palabra = new char[50];
    for (int i = 0; i < 50; i++) Palabra = ';';
    public boolean digitosValidos ()
    if (linea.charAt(linea.length()-1) != ';')
    System.out.println("Error: Frase no Finaliza");
    return false;
    for (int i = 0; i < linea.length(); i++)
    switch (linea.charAt(i))
    case 'a' : i++;
    break;
    case 'b' : i++;
    break;
    case 'd' : i++;
    break;
    case ';' : return true;
    case '^' : i++;
    break;
    default: return false;
    return true;
    public boolean esOracion ()
    while (linea.charAt(loc) != ';')
    { // Ciclo1 que verifica el final de la "Frase".
    int j = 0;
    while (linea.charAt(loc) != '^')
    { // Ciclo2 que verifica el final de la "Palabra".
    Palabra[j] = linea.charAt(loc);
    loc = loc + 1; // Aumenta la localizacion en el String.
    } // Fin Ciclo2
    if (!esPalabra()) System.out.println("Error: Palabra no Valida");
    } // Fin Ciclo1
    return false;
    public boolean esPalabra ()
    { // Determina si un fragmento del String dado es una Palabra.
    if (nmroSilabas % 2 == 1) return true;
    return false;
    public boolean esSilaba (int pos)
    { // Determina si un segmento del String dado es una silaba.
    int aux = pos + 2; // Elemento 2 casillas adelante.
    if (esExplosion(pos)) return true;
    if (esExplosion(pos) && esAlto(aux)) return true;
    if ((linea.charAt(++pos) == 'a') && esExplosion(pos)) return true;
    if (esExplosion(pos) && (linea.charAt(++pos) == 'a')) return true;
    return false;
    public boolean esExplosion (int pos)
    { // Determina si un segmento del String dado es Explosion.
    if (esAlto(pos) && (linea.charAt(++pos) == 'a')) return true;
    return false;
    public boolean esAlto (int pos)
    { // Determina si un segmento del String es Alto.
    if (linea.charAt(pos) == 'b') return true;
    if (linea.charAt(pos) == 'd') return true;
    return false;
    Aghhhhhhhh too lazy to translate the whole thing but know this
    esAlto - isHigh
    esExplosion - isExplotion
    esSilaba - isSyllable
    esPalabra - isWord
    esOracion - isSentence
    Anyway I'm doing well one checking for High, for Explotion but I GET STUCK HERE:
    take: ababadada
    Now I can have 4 <explotions>, making 4 syllables which wouldn't make a word IN MONKEY LANGUAGE!
    but if I take them as <explotion><high> and a<explostion> I get a VALID WORD IN MONKEY LANGUAGE! because I get 3 syllables.
    What's really killing me, it's how to make a function that will check all posible ways to make syllables, and then count them 'til they are an uneven number of syllables which would = word. and ofcourse there will be words that no matter the number of ways you try it, the number of syllables will be even such as "badadbaad" - which makes monkey3 fake monkey.
    I hope you get what I'm trying to solve here, any aid would be appreciated.
Draft saved Draft deleted
