goc9000
- 7
Hello all,
As part of a Control Theory assignment I have to compute the step response for the discrete-time LTI system given by the following state-space matrices:
[tex]
A = \[ \left( \begin{array}{ccc}
0 & 1 \\
0 & 3 \end{array} \right)\]
[/tex]
[tex]
B = \[ \left( \begin{array}{ccc}
0 \\
1 \end{array} \right)\]
[/tex]
[tex]
C = \[ \left( \begin{array}{ccc}
1 & 0 \end{array} \right)\]
[/tex]
[tex]
X_0 = \[ \left( \begin{array}{ccc}
1 \\
[/tex]
The input is u(t) = 1(t), i.e. 1 for t [tex]\geq[/tex] 0 and 0 otherwise.
NOTE: The system is causal.
I have calculated the z-domain response to be:
[tex]y(z) = \frac{z^2-3z+3}{(z-1)(z-3)}[/tex]
To get the time-domain response I am supposed to compute the inverse Z transform via the residue theorem, and here I run into a little problem: if I run y(z) through the algorithm as it is, I get the time-domain response:
[tex]y(t) = -\frac{1}{2} + \frac{1}{2}3^t[/tex]
which is indeed the correct system response except for the point t=0, where y(t)=0 but the correct value should be 1 (this can be seen by multiplying X0 with C - a MATLAB simulation also agrees).
What's funnier is that if I just rearrange y(z) a bit:
[tex]y(z) = 1 + \frac{z}{(z-1)(z-3)}[/tex]
and compute the inverse Z transforms for the two terms separately, I get:
[tex]y(t) = \delta(t) -\frac{1}{2} + \frac{1}{2}3^t[/tex]
which is the "real" correct response.
I'm obviously doing something wrong since the result of a calculation really should not depend on the form of the terms... Can anyone help? :)
