• Support PF! Buy your school textbooks, materials and every day products Here!
Problem on Lagrangian
Consider a bead of mass m moving on a spoke of a rotating bicycle wheel. If there are no forces other than the constraint forces, then find the Lagrangian and the equation of motion in generalised coordinates. What is the possible solution of this motion?
Lagrange's equation of motion
Use cylindrical coordinates for the problem.
Let the origin be at the centre of the wheel and let the wheel lie on the rθ-plane such that θ=0 at the top of the wheel and θ>0 in the clockwise direction.
So, [itex]T = 0.5m(\dot{r}^{^2} + r^{2}\dot{\theta}^{2})[/itex] and [itex]U = mgrcosθ[/itex].
So, [itex]\frac{∂L}{∂r} - \frac{d}{dt}(\frac{∂L}{∂\dot{r}}) = 0[/itex]
[itex]\Rightarrow (mr\dot{\theta}^{2} - mgcosθ) - m\ddot{r} = 0[/itex]
[itex]\Rightarrow \ddot{r} = r\dot{\theta}^{2} - gcosθ[/itex]
and [itex]\frac{∂L}{∂θ} - \frac{d}{dt}(\frac{∂L}{∂\dot{θ}}) = 0[/itex]
[itex]\Rightarrow (-mgrsinθ) - mr^{2}\ddot{θ} = 0[/itex]
[itex]\Rightarrow \ddot{θ} = - \frac{g}{r}sinθ [/itex]
Do you think I've got the equations of motion right?
I have no idea how to work out the possible solution of the motion. Thoughts?
Answers and Replies
ehild
15,409
1,813
The last one is not correct. Take care whit the time derivative.
ehild
To be honest, I don't see how I've got things wrong with the time derivative. Of course, [itex]\dot{θ}[/itex] differentiated wrt time becomes [itex]\ddot{θ}[/itex], right?
Also, isn't r constrained to be smaller than the radius of the wheel. Doesn't this have an effect on the solution?
ehild
15,409
1,813
[itex] \frac{d}{dt}(\frac{∂L}{∂\dot{θ}}) = \frac{d}{dt}(mr^2\dot{θ})=2mr\dot r\dot {θ}+mr^2 \ddot {θ}[/itex]
You ignored the time dependence of r.
The text of the problem is not clear.
Does that wheel rotate in the horizontal or in the vertical plane? mg is an outside force, not force of constraint.
Is there something making the wheel rotate with a given angular speed, or does the wheel rote freely about a fixed axis?
I think you can assume the radius of the wheel arbitrary long.
ehild
Thanks for the pointer. :)
[itex]The text of the problem is not clear.
ehild
I think the wheel rotates in the horizontal plane because there are no forces apart from the given force of constraint and because the force of gravity is not a force of constraint. What do you think? Isn't this also why we can safely say that the wheel rotates freely?
So, if we assume that the radius of the wheel is arbitrarily large, would you say that under those assumptions, my solution is correct?
ehild
15,409
1,813
What is your solution?
If the wheel is free to rotate, it is part of the system. You have to include it into the Lagrangian.
Are you sure you copied the problem correctly?
How do you include the constraint?
ehild
Related Threads for: Problem on Lagrangian
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
