How to Calculate Dry Clay and Left-Over Mud for a New Mixture
In summary, to create a new mixture containing 45% clay, 7.7 tons of left-over mud and 1.3 tons of dry clay need to be mixed together. This will use up all of the left-over mixture. The problem can be solved by setting up two equations, one for the total weight and one for the amount of clay, with the unknowns being the quantity of left-over mud and the amount of dry clay added.
jetteichert
1. You have a quantity of drilling mud left over from a previous job. The mud contains 30% clay and 70% water. Your next job needs a mud with 40% clay and 60% water. How much dry clay needs to be mixed with some of the left-over mud to produce nine tons of a new mixture containing 45% clay? How much of the left-over mixture is used for the new batch?
2. None
3. An excel sheet I worked out, but it solves knowing the quantity of left over mud (user input). Sometimes it helps me think when I work anything.
Okay I am not looking for an answer to this problem (I changed the % and weight anyway). I am actually looking for a second opinion on this problem. To me it is impossible to solve without knowing the amount of left over mud, does anyone else disagree or agree?
My professor seems to give problems that are way to easy or are lacking information unless you have taken higher classes then what I am in (luckily I procrastinated this basic class).
The mathematician's trick is to give your unknowns names, and express all relations between them as equations.
In this case, I suggest letting x be the quantity (in tons) of left-over mud that you are using and y the amount of dry clay that you add.
Those are two unknowns, so you will need two relations between them. Those could be equations for the total amount x + y, and for the amount of clay. Does that help you taking a shot at it?
Moderator's note: the OP has informed the Mentors that s/he has solved the problem.
In that case, for future reference, let me write down the two equations that I had in mind.
The first one expresses the total weight of 9 tons,
x + y = 9.
The percentage of clay should be equal to
0.30x + y = 0.40(x + y) = 9 . 0.40
(or 0.45, the OP is not really consistent here).
This gives two equations which can be solved for x and y, giving x = 54/7 and y = 9/7 (i.e. you should mix about 7.7 tons of old mud with 1.3 tons of dry clay).
I would approach this problem by first calculating the total weight of the left-over mud. Since we know that the mud contains 30% clay and 70% water, we can use this information to determine the weight of clay and water in the left-over mud.
Using the given percentages, we can set up the following equations:
Let x = total weight of left-over mud
0.3x = weight of clay in left-over mud
0.7x = weight of water in left-over mud
Next, we can calculate the weight of dry clay and water needed for the new mixture. Since we need a total of nine tons of the new mixture and it contains 45% clay and 55% water, we can set up the following equations:
Let y = weight of dry clay needed
0.45(9 tons) = 4.05 tons = weight of clay in new mixture
0.55(9 tons) = 4.95 tons = weight of water in new mixture
Now, we can set up an equation using the weight of clay in the left-over mud and the weight of dry clay needed for the new mixture:
0.3x + y = 4.05
Solving for y, we get y = 4.05 - 0.3x
To determine the amount of left-over mixture that needs to be used, we can set up an equation using the weight of water in the left-over mud and the weight of water needed for the new mixture:
0.7x + 4.95 = total weight of left-over mud + weight of water needed for new mixture
Since we know that the total weight of left-over mud is x, we can substitute this into the equation and solve for x. This will give us the total weight of the left-over mud, which we can then use to determine the amount of left-over mixture needed for the new batch.
In summary, to calculate the dry clay and left-over mud for a new mixture, we need to first determine the total weight of the left-over mud. Then, we can use this information to calculate the weight of dry clay and water needed for the new mixture. Finally, we can use the weight of water in the left-over mud to determine the amount of left-over mixture needed for the new batch. Without knowing the amount of left-over mud, it would be impossible to accurately calculate the dry clay and left-over mud
1. What is the process of problem solving?
The process of problem solving involves identifying the problem, gathering information and data, creating potential solutions, evaluating and choosing the best solution, and implementing and monitoring the solution.
2. How can I improve my problem solving skills?
To improve problem solving skills, you can practice regularly by solving various types of problems, think creatively and outside the box, break down complex problems into smaller parts, and learn from past experiences and mistakes.
3. What are some common barriers to effective problem solving?
Some common barriers to effective problem solving include lack of information, fear of failure, narrow-mindedness, and emotional biases. These barriers can prevent individuals from considering all possible solutions and hinder their problem solving abilities.
4. How do I know which solution is the best?
The best solution is typically the one that addresses the problem most effectively and efficiently, taking into consideration various factors such as feasibility, cost, and potential outcomes. It is important to evaluate and compare potential solutions before making a decision.
5. Can problem solving skills be learned?
Yes, problem solving skills can be learned and developed through practice, critical thinking, and learning from experiences. By actively seeking out and solving problems, individuals can improve their problem solving abilities and become better at finding solutions in various situations.
  • Science and Math Textbooks
  • STEM Academic Advising
