Problem to do with curls
  1. Jan 20, 2009 #1
    If r is the position vector in three dimensions, a is a constant vector and [tex]\nabla[/tex] is the gradient operator, evaluate
    [tex]\nabla[/tex] x (a x r).
    I don't understand what a constant vector is, it can't be the same as a scalar function. I've searched for a while and couldn't find anything that made sense, so any help would be vey much appreciated.
  3. Jan 20, 2009 #2
    gabbagabbahey
    A constant vector is a vector whose length and direction do not depend on position.
    For example; v=i+2j+687k qualifies as a constant vector. Its components are not functions of position.
    In contrast, the vector v=3x2j is not a constant vector since its lentgh depends on position (specifically where you are along the x-axis)
    Since constant vectors do not vary with position, their curl, divergence and gradient are all zero.
  4. Jan 20, 2009 #3
    but if the constant vector is first "crossed" with the position vector... shouldn't it give me some values...
  5. Jan 20, 2009 #4
    ohhhh but they cancel out... ahhh i see. Your right. Thank you gabbagabbahey :)
  6. Jan 20, 2009 #5
    gabbagabbahey
    Careful...
    [tex]\vec{\nabla}\times\vec{a}=\vec{\nabla}\cdot\vec{a}=\vec{\nabla}(\vec{a})=0[/tex]
    But that doesn't necessarily mean
    [tex]\vec{\nabla}\times(\vec{a}\times\vec{r})=0[/tex]
    You should find the following vector identity useful:
    [tex]\vec{\nabla}\times(\vec{A}\times\vec{B})=(\vec{B}\cdot\vec{\nabla})\vec{A}-(\vec{A}\cdot\vec{\nabla})\vec{B}+\vec{A}(\vec{\nabla}\cdot\vec{B})-\vec{B}(\vec{\nabla}\cdot\vec{A})[/tex]
  7. Jan 20, 2009 #6
    hmmm okay, if A is a constant vector and div A is equal to 0 then the above formula reduces to
    [tex]\vec{\nabla}\times(\vec{A}\times\vec{B})=(2(\vec{B}\ \cdot \vec{\nabla})\vec{A})[/tex]
    right?
    is
    [tex](\vec{B}\ \cdot \vec{\nabla}) = (\vec{\nabla}\ \cdot\vec{B}) [/tex]
  8. Jan 20, 2009 #7
    gabbagabbahey
    No,
    [tex](\vec{B}\ \cdot \vec{\nabla}) \neq (\vec{\nabla}\ \cdot\vec{B}) [/tex]
    In Cartesian coordinates,
    [tex](\vec{B}\ \cdot \vec{\nabla})= B_x\frac{\partial}{\partial x}+B_y\frac{\partial}{\partial y}+B_z\frac{\partial}{\partial z} [/tex]
    which is a differential operator that operates on whatever vector is on the right of the operator.
    Of course, any differential operator that operates on a constant vector will be taking some derivative of some constant and therefor gives a result of zero.
    Therefor, [tex](\vec{r}\cdot \vec{\nabla})\vec{a}=0[/tex]
    And
    [tex]\vec{\nabla}\times(\vec{a}\times\vec{r})=-(\vec{a}\cdot \vec{\nabla})\vec{r}+\vec{a}(\vec{\nabla}\cdot\vec{r})[/tex]
  9. Jan 20, 2009 #8
    gabbagabbahey
    You can then use the fact that [tex]\vec{r}=x\hat{x}+y\hat{y}+z\hat{z}[/tex] to simplify further.
Similar Discussions: Problem to do with curls
  1. Curl problem (Replies: 2)
  2. Curl problem (Replies: 3)
Loading...
