lm93
- 15
A cubic box of volume 4.0 multiplied by 10-2 m3 is filled with air at atmospheric pressure at 20°C. The box is closed and heated to 160°C. What is the net force on each side of the box?
P1/T1=P2/T2
P=F/A
So we can assume that volume is constant because the box is closed. P1=1 atm P2=unknown
T1=20C T2=160C. Using the above equation I got: 1/20=P2/160--> 1/20*160=P2-->P2=8 atm
Then to find the force I thought I should use F=PA. I converted 8 atm into N/m2 and got 810 600N/m2. For the area of one side of the box, I thought that one length of the cubic box was the cube root of 0.04 squared which I found to be 0.11696m2. So then, I put those numbers into the equation and got F=PA--> F=0.11696*810600--> F=94808.35N
But this was wrong
I have tried this problem many different times and keep getting it wrong. I was wondering if it matters the units you use for the first equation P/T=P/T. I thought as long as you kept them constant it didn't...but then when I tried it with different units eg. Kelvins instead of degrees Celsius I got a different answer.
Could someone please help? I would really appreciate it!
Thank you
