• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Problem with acceleration
  • Thread starter Ugnius
Moved from technical forums, so no template
Hi , im trying to practice working with new exercises and i've met some problems.
Lifting object with mass of 2kg to height of 10m we do 240J mechanical work.
What is acceleration of lifting?
My calculations:
A=Fs=Fh
F=A/h = 240/10 = 24N
a= F/m = 24/2 = 12 m/s^2 , somehow it's not the right answer
70
There is a downward mg which compensates the mechanical work done?
your answer is correct if there is no mg force
in fact,part of the mechanical work done is to compensate the work done by the mg force
24
No , that's all what's written in question
28,019
4,416
The word "lifting" implies gravity.
70
the final answer is 2 ?
24
2 m/s^2 yes
70
in fact
your answer is correct if there is no gravity.
70
if there is gravity
then you will feel a "resistance" from the gravity
part of your 240J will try to compensate this "resistance" so that it is impossible that the force that you provide will be the same of the case of no gravity force
24
How did you get 2? can you write the equation?
Was it a=F/m - g?
haruspex
Insights Author
2018 Award
31,375
4,592
I'm unsure how to interpret the question.
If this is in a terrestrial setting, we can calculate that part of the work that went into overcoming gravity, i.e. into achieving the PE gain. That is less than 240J. Where did the rest go? Since it asks about acceleration, maybe we are supposed to assume there is residual KE, i.e. it is still moving upwards. If so, we can compute the gained velocity, but without knowing how long this took there is no way to find the acceleration.
Alternatively, this is extraterrestrial, and all they want you to find is the local gravitational acceleration, but then that would be 12m/s2, not 2.
NascentOxygen
Mentor
9,184
1,033
The object was lifted 10m.
haruspex
Insights Author
2018 Award
31,375
4,592
Yes, although it isn't stated, I think maybe the solution should assume constant acceleration.
That does seem to be the most likely error/omission in the question.
Want to reply to this thread?
"Problem with acceleration" You must log in or register to reply here.
Related Threads for: Problem with acceleration
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
