Problem with Fortran g77 code
  1. Jan 18, 2010 #1
    Hi,
    I received a code written in Fortran 77, and I am trying to compile it and run it using g77. It compiles easily with no errors, but I keep getting the following error when I execute
    errorfmt: read unexpected character
    apparent state: unit 5 named jeffin
    last format: (10X,D13.7)
    lately reading sequential formatted external IO
    Aborted
    Any idea what this error means?
  3. Jan 19, 2010 #2
    Mark44
    Staff: Mentor
    It looks to me like your error is coming from an input READ statement where the format string is in disagreement with what your program is trying to read.
    I can't say any more than that because I don't see your code and I don't know what the input was.
  4. Jan 19, 2010 #3
    Sorry, here are the codes I used in the zipped folder. The code JEFF.FOR compiles fine, but I cannot find an error in how the read command takes in the input file called jeffin. If you can help me out, I would really appreciate it!
    Donna
  5. Jan 19, 2010 #4
    jtbell
    Staff: Mentor
    In principle, it's possible to figure out which of your READ statements is failing, by tracing through the code carefully by hand, one statement at a time, and matching each READ statement with a line in your input file to see if the format matches properly.
    However, it's easy to make mistakes doing this. Instead, get the computer to do the work for you! :smile:
    Immediately after each READ(5... statement, insert a statement which displays the value that it just read in. For example, after
    READ(5,99)NEIGEN
    add
    PRINT *, "NEIGEN = ", NEIGEN
    If the appropriate line in your input is actually being read properly, you should see the message
    NEIGEN = 2
    The last such output line before the error message will tell you which READ statement failed... it's the next one!
  6. Jan 19, 2010 #5
    Thanks!
    This really helped. I found the error. I had the format 102 written as (10X,D13.7) and when I put instead (20X, D13.7) it runs.
