What is the Origin of the Friction Force in Surfer's Motion on a Wave?
In summary, the surfer is standing on a board at an angle of 10º to the horizontal and is being accelerated by a wave at a rate of 1.0m/s^2. There is a force preventing the surfer from sliding over the board. By analyzing the forces acting on the surfer, it can be determined that the friction force is approximately 188N. This is due to the combination of gravity and the surfer's acceleration.
Hernaner28
263
The surfer (70kg) is standing over a board which has an angle of 10º with the horizontal. A wave acelerates him to the right at 1.0m/s^2. There is a force that prevents the surfer from sliding over the board.
Calculate that force. What's the origin of this force?
What I did was to analize the surfer only and since there's horizontal aceleration to the right then there's a wave force in horizontal direction to the right. So I just analized it in axis x given the faact that at axis y it doesn't move. So the equations:
http://eva.fing.edu.uy/filter/tex/pix.php/fa2415fb159333cacb5c7a42d79502d8.png
http://eva.fing.edu.uy/filter/tex/pix.php/093b650ee4c9116ddcd68135cf37b616.png
Then I calculated the weight at axis x:
http://eva.fing.edu.uy/filter/tex/pix.php/857f0c71f94a74d9cb6e58fc3e611cfe.png
So the friction force has to be the difference among these two and in the direction of the wave force and it would be 50N but the option is not in the moddle multiplechoice I'm doing.
Thanks!
Thanks!
Hi, in my opinion the answer is the following: in the (accelerated) frame where the man is at rest the following forces act on the man: gravity (m g), inertial force (-m a), the reaction of the table which is perpendicular to the plane of the board (R) and and friction (F) which is parallel to the board; if you sum (vectorially of course) all these force you should obtain zero in order to say that the man is in equilibrium over the board; you have then two equations in two unknowns (F and R); solving the system I obtain
[itex]F=m(g [/itex] sin[itex](\theta) +a[/itex] cos[itex](\theta))[/itex]
substituting [itex]\theta=10°[/itex], [itex]a=1\frac{m}{s^2}[/itex], [itex]m=70Kg[/itex], I obtain
F≈188N
Oh yes! You're right! I forgot that the inercial force is negative! Thanks!
1. What is friction force?
Friction force is a force that resists the relative motion or tendency of motion between two surfaces in contact. It is caused by the roughness of the surfaces and the interlocking of their microstructures.
2. What are the types of friction force?
The three main types of friction force are static friction, kinetic friction, and rolling friction. Static friction occurs when there is no relative motion between two surfaces, kinetic friction occurs when there is relative motion between two surfaces, and rolling friction occurs when an object rolls over a surface.
3. How does friction force affect motion?
Friction force can either help or hinder motion. In some cases, friction force can provide necessary traction for objects to move and stay in place. However, in other cases, friction force can slow down or prevent motion, such as in a car's brakes.
4. What factors affect the amount of friction force?
The amount of friction force depends on the roughness of the surfaces in contact, the amount of force pushing the surfaces together, and the type of material the surfaces are made of. Other factors such as temperature and lubrication can also affect the amount of friction force.
5. How can friction force be reduced?
Friction force can be reduced by using lubricants, such as oil or grease, between surfaces. It can also be reduced by making the surfaces smoother or by using materials with lower coefficients of friction. In some cases, reducing the force pushing the surfaces together can also decrease friction force.
