aldaris565
- 5
A proton travles with a velocity 8x10^5 m/s E=10^6 V/m and B= 1.5 T. Draw the path of the proton and what is speed of the proton when it comes out?
Here an image:
aldaris565 said:Well just replace with the values given...I'm stuck i don't know if that's correct or not... I decided do it with all variables and then replace them...
I guess i sould integrate the speed getting the position (x,y) but I'm not sure if that's correct...
I need help.. I HAVE to resolve this problem...
I need ideas you don't have to resolve all the problem.. just give me ideas!
berkeman said:What is the shape of the path of a charged particle in a uniform magnetic field?
You correctly list the Lorentz force as the force that is acting on the proton in the magnetic field (there is no E field, right?). What does that Lorentz force do to the path of the proton? Draw the path, and plug in the numbers for the force. The force acts over a finite distance of the proton's trajectory -- what is the resulting trajectory when the proton leaves the B-field region?
aldaris565 said:But in the problem exist an E field... the trajectory doesn't have to be exact... i guess it's a Uniform Circular Movement.
If i'd do:
First for t=0 -> x=0 y=0.05
Then:
Finding t=? for x=0.3 y=0.05
That would be correct¿? then i replace that value of t in the formula of the speed... would i get the final speed (when it comes out) ??
aldaris565 said:The integrals are no so complicated... but in another forum someone told me that the proton never leaves and the path i guess it's not a straight line, because qE is diferent that q(vxB) [q(vxB) and qE are in opossite directions but they aren't equals to eliminate them...]
The Earth's magnetic field is weakening and its poles are shifting, which can have significant impacts on our planet's climate and navigation systems.
Scientists believe that changes in the Earth's core, specifically the flow of molten iron, are responsible for the weakening of the magnetic field.
The weakening of the magnetic field can lead to an increase in solar radiation reaching the Earth's surface, which can be harmful to human health and also disrupt communication and navigation systems.
No, the Earth's magnetic field has weakened in the past and then recovered. However, it is uncertain how long it will take for the field to recover this time, and some scientists believe that a complete reversal of the poles may occur.
Scientists use satellites, ground-based instruments, and mathematical models to continuously monitor and study the Earth's magnetic field. This helps us better understand the causes and impacts of changes in the magnetic field.
