Problem with Matlab
  1. Jan 7, 2012 #1
    Hi everyone,
    I am having a bit of a problem with Matlab. I am currently using a finite difference mesh to solve the heat equation across one spatial dimension - x and time. I had an water array with depth and time and a boundary condition given by heat transfer equations which set the top line. This ran perfectly fine downwards from 2 : end-1
    I then added an array above it that was the same but had air properties. From this I set the bottom row to a boundary condition using the heat transfer equations and tried to run it the same way but upwards from end-1 : 2.
    It will not work and just alters the bottom row. The second differentials from the finite difference model come up as 0 despite their consituent parts clearly not adding to 0 uppon logging.
    (the model is trying to show heat interaction between an air layer sat on a water layer and heat transfer within the 2 layers in assumed to be conduction only)
    Can anyone suggest a solution to this or a problem it may be?
    Can MATLAB handle running upwards through a mesh?
    Thanks for any help, ( I am happy to give you more information)
    Matt
  3. Jan 7, 2012 #2
    Re: Matlab
    If you want to step in the negative direction you need to tell matlab so.
    Use: end-1 : -1: 2
    That should work
  4. Jan 9, 2012 #3
    Re: Matlab
    Thanks, I will try it now
    It didn't work. The only way I have been able to do it is by putting a new for loop in that runs a variable up the array and use that to work up the array but it looks a lot messier than it should be...
