Solving for Car Mass with Gauge Pressure and Surface Area | Physics Problems
  • Thread starter jrd007
  • Tags
    Fluids
In summary: HeliumSo that means...(930 kg) + (297 kg) + cargo mass = F_boyancyBut what is cargo mass?I don't know how to get it.In summary, the conversation discusses various problems related to fluid mechanics. The first problem involves estimating the mass of a car based on the pressure in its tires and the area of the tires' "footprint." The second problem involves calculating the maximum cargo that a balloon filled with helium can lift, taking into account the weight of the balloon structure and the buoyant force of the helium. The third problem requires identifying the likely identity of a metal based on its mass in air and
  • #36
Actually you you can just minus the two to get the water displaces and change it into kg = .0081
63.5/.0081 = 7839! :)
<h2>1. What is the formula for solving for car mass using gauge pressure and surface area?</h2><p>The formula for solving for car mass using gauge pressure and surface area is: <strong>mass = (gauge pressure x surface area) / gravitational acceleration</strong>.</p><h2>2. How do I determine the gauge pressure of a car?</h2><p>The gauge pressure of a car can be determined by using a pressure gauge or by measuring the weight of the car and dividing it by the surface area in contact with the ground.</p><h2>3. Can I use any unit of measurement for gauge pressure and surface area in the formula?</h2><p>Yes, as long as the units for gauge pressure and surface area are consistent (e.g. both in SI units or both in imperial units), any unit of measurement can be used in the formula.</p><h2>4. What is the significance of solving for car mass using gauge pressure and surface area?</h2><p>Solving for car mass using gauge pressure and surface area can help determine the weight of the car and its impact on the surface it is in contact with. This can be useful in understanding the performance and safety of the car, as well as in designing roads and structures to support the weight of cars.</p><h2>5. Are there any other factors that may affect the accuracy of the calculated car mass?</h2><p>Yes, there are other factors that may affect the accuracy of the calculated car mass, such as the distribution of weight within the car, air resistance, and friction between the car and the surface. These factors should be taken into consideration when using this formula.</p>
The formula for solving for car mass using gauge pressure and surface area is: mass = (gauge pressure x surface area) / gravitational acceleration.
