Problems with negatives.
PrincePhoenix
1st problem:
A small object of size 0.5 mm is placed close to a convex lens of focal length 5cm. The virtual image formed is at a distance of 25 cm from the lens. Find magnification.
Data:
focal length, f = 5cm
distance of image , q = -25 cm (because image is virtual)
distance of object , p = ?
magnification, M = ?
1/f = 1/p + 1/q
M = height of image/height of object = q/p
(ratio between height and distance of image and object)
Solution:
First finding p,
1/f = 1/p + 1/q
1/p = 1/f - 1/q
1/p = 1/5 - (1/-25)
1/p = 6/25
p = 25/6 = 4.16cm
Now putting value of 'p' in magnification formula,
M = -25/4.16
M = -6
Can magnification be -ve? It is so in this problem. What have I done wrong?
2nd problem:
1-This part of a numerical problem as our teacher did it in classroom.
Data:
distance of object, p = 20cm
focal length of concave lens,f = -19 (Is focal length of concave lens really always -ve?)
distance of image, q = ?
Solution:
According to lens formula,
1/f = 1/p + 1/q
=> 1/q = 1/f - 1/p
1/q = 1/-19 - 1/20
1/q = -20-19/380
1/q = -39/380
q = -9.74cm
Why can't LCM be negative at line 4,5 of solution when one of the denominators is -ve? And is the -ve value of distance of image correct?
Answers and Replies
Redbelly98
Staff Emeritus
Insights Author
12,117
154
1st problem:
Data:
1/f = 1/p + 1/q
It should be -q/p in that equation.
Solution:
First finding p,
1/f = 1/p + 1/q
1/p = 1/f - 1/q
1/p = 1/5 - (1/-25)
1/p = 6/25
p = 25/6 = 4.16cm
M = -25/4.16
M = -6
See previous note.
By the way, magnification can be negative, and is when q and p are both positive.
2nd problem:
Data:
Solution:
1/f = 1/p + 1/q
=> 1/q = 1/f - 1/p
1/q = 1/-19 - 1/20
1/q = -20-19/380
1/q = -39/380
q = -9.74cm
The LCM could be -380, but most people consider it easier to move the negative sign to the numerator and use a positive denominator.
For a negative denominator, this becomes
1/(-19) - 1/20
= 20/(-380) + 19/(-380)
= (+20 +19)/(-380)
= ___?
PrincePhoenix
What does negative magnification mean anyway?
Redbelly98
Staff Emeritus
Insights Author
12,117
154
It means the image is inverted, relative to the object. (Their heights have opposite signs.)
Related Threads on Problems with negatives.
  • Last Post
13K
  • Last Post
  • Last Post
12K
