Transforming Penicillin G Salts to Acids: A Guide
  • Thread starter proca
  • Tags
    Acids
In summary, the conversation discusses the use of penicillin G and penicillin G procaine in medicine. Penicillic acid, an antibiotic substance, is produced by certain species of Penicillium and Aspergillus. The procaine salt of penicillin G, also known as penicillin G procaine, is used for intramuscular injections to reduce pain. The question is whether it is possible to convert penicillin sodium salt back to penicillic acid and then combine it with procaine to create penicillin G procaine. The discussion also touches on the potential effects of using varying levels of procaine in the solution.
proca
Hi all, I need some help!
some info:
Penicillic acid [CAS RN: 90-65-3]: an antibiotic substance produced by several species of Penicillium and Aspergillus
Penicillin G
: Used in medicine. It is used in the form of its stable salts (benzathine, potassium, procaine, and sodium)
Penicillin G Procaine
[CAS RN: 6130-64-9]: the procaine salt of penicillin G; Chemically designation is (2S,5R,6R)- 3,3-Dimethyl-7-oxo-6-(2-phenylacetamido)-4-thia-1-azabicyclo [3.2.0] heptane-2-carboxylic acid WITH 2-(Diethylamino)ethyl p-aminobenzoate (1:1)I have penicillin g as sodium salt and procaine, but have not and can't find penicillin g as procaine salt.
Is there any way to revert from penicillin sodium salt to penicillic ACID and then to make solution with procaine to get the penicillin as procaine salt (not sodium)?How the salts should be transformed into acids?
Chemistry news on Phys.org
In the medical practice is used a solution containing only 1% procaine and penicillin g sodium, here the procaine salt's goal is just to be an anesthetic - to make the intramuscular injection free of pain, but what happens if we make a solution of for example 100% procaine (not 1%), what happens with the sodium salt, it's going to be a mess of 50% procaine and 50% sodium salt or what?
What is the purpose of transforming Penicillin G salts to acids?
The purpose of transforming Penicillin G salts to acids is to create a more stable form of penicillin that can be more easily transported and stored. This transformation also allows for the acid form of penicillin to be more easily administered to patients.
What are the steps involved in transforming Penicillin G salts to acids?
The steps involved in transforming Penicillin G salts to acids include dissolving the salts in water, adding a strong acid such as hydrochloric acid, and then filtering and drying the resulting solution. This process converts the Penicillin G salts into the acid form.
What are the benefits of using acid form of Penicillin G?
The acid form of Penicillin G has several benefits, including increased stability and solubility. This allows for easier storage and transportation, as well as improved absorption and effectiveness when administered to patients.
Are there any risks associated with transforming Penicillin G salts to acids?
While the transformation process itself is relatively safe, there can be potential risks if proper precautions are not taken. The strong acids used in the process can be corrosive and may cause harm if handled improperly. It is important to follow safety protocols and wear protective gear when working with strong acids.
Can this transformation process be applied to other antibiotics?
Yes, this transformation process can be applied to other antibiotics that have a similar chemical structure to Penicillin G. However, it is important to note that the process may vary depending on the specific antibiotic being transformed. It is recommended to consult with a trained professional before attempting to transform other antibiotics.
