Product of two summations
114
A and B are matrices and x is a position vector. Show that
$$\sum_{v=1}^n A_{\mu v}(\sum_{\alpha = 1}^n B_{v\alpha}x_{\alpha})=\sum_{v=1}^n \sum_{\alpha = 1}^n (A_{\mu v} B_{v\alpha}x_{\alpha})$$
$$= \sum_{\alpha = 1}^n \sum_{v=1}^n(A_{\mu v} B_{v\alpha}x_{\alpha})$$
$$= \sum_{\alpha = 1}^n (\sum_{v=1}^n(A_{\mu v} B_{v\alpha})x_{\alpha})$$
N/A
I tried expanding the summations out and multiplying the two brackets each with n terms, but then factorization of the product simply led back to what was first given in the question. I also tried visualizing the problem as matrices, but to no avail. This isn't really homework/part of my portion, but I'm trying to get a hand of tensors and for that I need to understand summations. I'm familiar with basic summation procedures for finding out standard deviation etc but nothing of this sort. Any help is appreciated.
Answers and Replies
BvU
14,401
3,713
This is actually asking you to prove that ## \vec{\vec A}\; \left ( \vec{\vec B} \;\vec x\right ) = \left ( \vec{\vec A} \; \vec{\vec B} \right ) \vec x ## , right ?
I don't think I understand what you did when you tried this "factorization of the product". Wouldn't it be more a thing like "grouping of the terms"?
114
Yes, I tried grouping the terms after expansion and sort them in such a way that they can be reduced to a summation sequence but it didn't work for me.
114
The result appears to be intuitive but it's just that I can't find a way to show it on paper.
BvU
14,401
3,713
But they are already in a summation sequence. The only thing that really happens is the interchange of the summations.
114
But how do I show that they're interchangeable?
BvU
14,401
3,713
Hmm, I don't have an obvious answer to that. In ProofWiki they do an even more general case (x is a matrix C and the matrices aren't even square). THey work from the two ends towards the middle and then 'use associativity' of the contraction. But it's tough to read for a physicist.
Could you check it out ?
114
Thanks for the link. So a proof that shows matrix multiplication is associative is as good as a proof that shows that multiplication of summation sequences is associative? If so, does this hold universally for all summation sequences?
P.S. The proof seems to be easy enough to follow :)
BvU
14,401
3,713
Hey, I'm just a physicist. Switch summations without blinking an eye :wink: Interchange summation and integration as if it were nothing (not even with fingers crossed).
If you find this proof easy enough to follow, you're better equipped than I am to generalize. (But I think it's OK :smile: ).
You want me to invite an expert on the homework helpers forum ? (Because I realize I can't really underpin that)
114
No, it's fine really. I doubt I'll be requiring a rigorous mathematical proof of this sort to proceed with my studies, and besides, I'm just doing this to expand my understanding on metrics. I'd be happier understanding the application of it's principles rather than getting stuck onto the algebra. Thanks!
PeroK
Insights Author
2020 Award
17,152
8,952
If you have two summations multiplied, you get one of every combination of the indices, regardless of the order:
$$\sum_{i=1}^n A_{i}\sum_{j = 1}^m B_{j}=A_1(B_1 + B_2 + \dots + B_m) + \dots ... + A_n(B_1 + B_2 + \dots + B_m)$$
$$= (A_1 + A_2 + \dots + A_n)B_1 + \dots ... +(A_1 + A_2 + \dots + A_n)B_m$$
$$=\sum_{j=1}^m (\sum_{i = 1}^n A_{i})B_{j}$$
Etc.
Likes BvU and PWiz
PeroK
Insights Author
2020 Award
17,152
8,952
Alternatively, you can use induction on n. Here's the inductive step:
$$\sum_{v=1}^n A_{\mu v}(\sum_{\alpha = 1}^n B_{v\alpha}x_{\alpha})$$
$$= \sum_{v=1}^{n-1} A_{\mu v}(\sum_{\alpha = 1}^{n-1} B_{v\alpha}x_{\alpha}) + \sum_{v=1}^{n-1}(A_{\mu v} B_{vn}x_{n}) + A_{\mu n}(\sum_{\alpha = 1}^n B_{n\alpha}x_{\alpha})$$
$$= \sum_{\alpha = 1}^{n-1} \sum_{v=1}^{n-1}(A_{\mu v} B_{v\alpha}x_{\alpha}) + \sum_{v=1}^{n-1}(A_{\mu v} B_{vn}x_{n}) + A_{\mu n}(\sum_{\alpha = 1}^n B_{n\alpha}x_{\alpha})$$
$$= \sum_{\alpha = 1}^{n} \sum_{v=1}^{n-1}(A_{\mu v} B_{v\alpha}x_{\alpha}) + A_{\mu n}(\sum_{\alpha = 1}^n B_{n\alpha}x_{\alpha})$$
$$= \sum_{\alpha = 1}^{n} \sum_{v=1}^{n}(A_{\mu v} B_{v\alpha}x_{\alpha})$$
Related Threads on Product of two summations
  • Last Post
28K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
