Unraveling the Implicit Differentiation of y=vx
In summary, implicit differentiation is used when both variables in an equation are functions of the same independent variable and cannot be treated as constants.
thomas49th
655
Consider
y = 2a + ax
find dy/dx
dy/dx = a
That is right is it not, as a is treated merly as a constantNow consider this question:
Use the substitution y = vx to transform the equation:
dy/dx = (4x+y)(x+y)/x²
into
x(dv/dx) = (2+v)²
According to the mark scheme they
differentiate dy/dx implicitally
y = vx
dy/dx = x(dv/dx) + v
BUT why have we differentitated implicitally?
In your first example, a is assumed to be a constant, so dy/dx = a, as you showed.
In your second example, both x and y are variables, and v is some function of x. In the substitution y = vx, when you differentiate the right side with respect to x, you cannot treat v as a constant as you did in the first example, so you have to use the product rule. You are assuming that both y and v are functions of x, so any differentiation has to be done implicitly.
What is implicit differentiation and how is it related to y=vx?
Implicit differentiation is a mathematical technique used to find the derivative of a function that is not explicitly written in terms of its independent variable. In the equation y=vx, implicit differentiation is used to find the derivative of y with respect to x.
What are the steps to perform implicit differentiation on y=vx?
The steps to perform implicit differentiation on y=vx are as follows:
  1. Write the equation in the form of f(x,y)=0.
  2. Differentiate both sides of the equation with respect to x.
  3. For each y term, multiply by dy/dx.
  4. Collect all terms with dy/dx on one side and factor it out.
  5. Solve for dy/dx to find the derivative of y with respect to x.
What is the importance of implicit differentiation in mathematics?
Implicit differentiation is important in mathematics because it allows us to find the derivative of a function even when it is not explicitly written in terms of its independent variable. This is useful in solving many real-world problems in physics, engineering, and economics, where relationships between variables are often not explicitly stated.
What is the difference between implicit differentiation and explicit differentiation?
Explicit differentiation is used to find the derivative of a function that is explicitly written in terms of its independent variable, while implicit differentiation is used to find the derivative of a function that is not explicitly written in terms of its independent variable. In other words, explicit differentiation can be used when the function is in the form of y=f(x), while implicit differentiation is used when the function is in the form of f(x,y)=0.
How can implicit differentiation be applied in real-world scenarios?
Implicit differentiation can be applied in many real-world scenarios, such as finding the rate of change in physics problems involving motion, determining the optimal production level in economics, or calculating the growth rate of a population in biology. It is a useful tool for analyzing relationships between variables and making predictions in various fields of study.
