Product rule
If it's not homework, then where does it come from?In summary, the conversation discusses the simplification of the equation y=3x2Inx and clarifies the meaning of Inx, which is the natural logarithm represented as ln x on a calculator. It is also pointed out that if v=ln(x), then dv/dx=1/x, not I/x. Finally, it is mentioned that the problem should be posted in the Homework & Coursework section.
anthonyk2013
125
y=3x2Inx
u=3x2
v=Inx
du/dx=6x
dv/dx=I/x
y=u*v
dy/dx=(u)(dv/dx)+(v)(du/dx)
dy/dx=(3x2)(I/x)+(Inx)(6x)
Can I simplify this further
anthonyk2013 said:
y=3x2Inx
What is Inx? If you are going by what is on a button on a calculator, that is ln x (LN), for natural logarithm.
anthonyk2013 said:
u=3x2
v=Inx
du/dx=6x
dv/dx=I/x
If v = ln(x), then dv/dx = 1/x, not I/x.
anthonyk2013 said:
y=u*v
Please post homework-type problems in the Homework & Coursework section, not in the technical math sections. I am moving this thread.
It's not homework!
But it's a homework-type problem, so this is where it goes.
What is the product rule?
The product rule is a mathematical rule used to calculate the derivative of a product of two functions. It states that the derivative of a product of two functions is equal to the first function multiplied by the derivative of the second function, plus the second function multiplied by the derivative of the first function.
Why is the product rule important?
The product rule is important because it allows us to find the derivative of complicated functions that are expressed as a product of two or more simpler functions. It is a fundamental rule in calculus and is used extensively in areas such as physics, engineering, and economics.
How do you use the product rule?
To use the product rule, you need to identify the two functions that are being multiplied together. Then, you take the derivative of each function separately and apply the formula: (first function)(derivative of second function) + (second function)(derivative of first function). This will give you the derivative of the original product function.
Can the product rule be extended to more than two functions?
Yes, the product rule can be extended to more than two functions. For example, if you have a product of three functions, the formula becomes: (first function)(derivative of second function)(derivative of third function) + (second function)(derivative of first function)(derivative of third function) + (third function)(derivative of first function)(derivative of second function). This pattern can be extended to any number of functions.
What is the difference between the product rule and the chain rule?
The product rule and the chain rule are two different rules used to find the derivative of a function. The product rule is used when the function is expressed as a product of two or more functions, while the chain rule is used when the function is composed of two or more functions. In other words, the product rule deals with multiplication, while the chain rule deals with composition.
