Program for designing simple circuits
In summary: For someone into electronics it is invaluable because so many components are available as included libraries.
exequor
393
Does anyone know of any software (preferably free) that can design relatively simple cicuits?
Electronic Workbench can design and test circuits, but it is not free.
try this page, it has plenty of CAD proggies to do just that. Go down to Electrical CAD systems to find the stuff specialized for electronics. Of course, you can still use other CAD proggies to do the diagrams as well. Most of these are free.
http://www.freebyte.com/cad/cad.htm
circuitmaker2000 has a student edition. Do a search for "SPICE circuit" on google and comb through the results. OrCAD has a trial version of PSpice also I think.
Are you looking for simulation software or software to generate circuits for you? Are you looking for analog or digital or mixed signal circuits?
The one I use is called Tina - really nice in that it generates various graphs, noise analysis, etc for ya, and has a full-featured (omit print) demo. See http://www.tina.com/ for more info.
Go for SPICE if you are EE or ECE major. SPICE is used extensivly in industry and will help you get a internship.
I was just looking for something simple right now that can be used to test simple electronics labs like to find the resistance of a voltmeter. but once I'm into EE i will get SPICE
For pspice you would have somthing like this for a voltage divider:
Code:
*voltage source from ground to node 1
V1 1 0 10V
*Resitor from node 1 to node 2
R1 1 2 1KOhm
*Resitor from node 2 to ground
R2 2 0 2kOhm
*show all node voltages in output file
.OP
Not hard even for simple circuits.
Here is a site with downloads and walk throughs if you want to take a closer look.
http://www.electronics-lab.com/downloads/schematic/013/index.html
Download a student/eval copy of OrCAD. It has a graphical schematic capture tool, and can do more than most practicing EEs need to be able to do. It has a steep learning curve, however. We're here to help you, should you need it. Davorak has made a reasonable suggestion, since OrCAD's GUI is typically the part that's hard to learn, and using a text-file based simulation would make sense for a circuit with fewer than say 10 components.
- Warren
electronic software
hi ya?
i want to just give you the best suggestion to use a software called TINA PRO 6 which is used in electronics. i don't know about the price or is it free but it is the best software i used to design electrical circuit.
No question
On this topic Chroot is dead on -- Pspice is the only way to go -- His comment on the learning curve is I believe correct it does take a little time and effort to learn -- but as opposed to what was said here it has a windows
interface you do NOT have to encode components by lines of code you can make a schematic very simply and then analyze it in the frequency or time domain . For someone into electronics it is invaluable because so many
components are available as included libraries . For instance many of Philips transistors to over 50 Ghz FT are available as complete non-linear models .
The student version is available free and I believe without time limit but it does restrict you on the compexity of the circiuts -- for many this is no
problem .
Pspice has been around for many years it is well proven in a type of software where there are many traps ---
If you learn this -- and maybe there are more modern versions ( it will
almost never let you down -- provided only you understand a little it's limits -- like any other software ) .
Ray
That is really bad advice
Pspice today is in windows format -- you can do schematic capture in very simple ways -- it takes seconds to set up a circuit and then analyze it
It is the only software I know which can accurately analyze a simple one transistor oscillator -- and tell you if there is some spurious oscillation at
a couple of Ghz . You do not have to write one single line of code .
But as Chroot said there is a learning curve you cannot expect to learn some complex tool in one second -- but this IS a good tool in my view
one of the best .
Ray
Code:
V1 1 0 10V
R1 1 2 1KOhm
R2 2 0 2kOhm
.OP
Hi,
I am in ECE. I am eager to learn PSPICE to make myself marketable when I go to work as an electrical engineer. I would problably learn it after my semester exam is over.
But can anyone suggest how should I go about starting to learn this software? First of all, I do not even have the software in my PC, so besides the Circuitmaker student edition being DL free, what other PSPICE software (free) can I use to learn? Actually, I agree with Chroot that for more complex circuits with like 20 components, it is a torture to write codes for simulation purposes, so it is better if there is Schematic drawing with simulation.
PSPICE has actually been discontinued. OrCAD (Cadence) absorbed it into another app. The language you want to learn is SPICE which was developed at Berkely. Do a google search for SPICE and you'll find about 987598375372597459027398745 different versions floating around. If you install Linux then you'll have a lot of F/OSS options available--many distros offer a spice option on install as well. OrCad still has a Psice download available; however, I don't know how much functionality it has.
To learn SPICE(or PSice) get ahould of one of the millions of online tutorials, think of a project(I usually recommend an H-Bridge designed from scratch because its a real good semiconductor learning tool), and keep playing with the software until you get everything working. That's basically how I (and many people I work with) learned to use this or any other software. Sit down and play with it for a little while. Start simple--an RLC ckt. Move on from there.
Well, good luck.
I got the OrCAD 9.2 group of software, I must say it has to be industry standard because there is everything in it even PCB design. Wow.
OrCAD 10.0 has been out for a while. OrCAD is one of a few different design packages you'll see used everywhere in industry. Protel and Pads are the most common competitors, and I honestly prefer Protel over OrCAD.
- Warren
Yea, i think OrCAD 10 even has Tina Pro and others.
One thing though, I am trying to recreate a simple experiment I had to do a few weeks ago, which involved finding the resistance of a voltmeter. So there was a powersupply, resistor and voltmeter all connected in series. The resistance was changed and you had to record the voltage shown on the voltmeter. I have designed that circuit in OrCAD capture and when i ran a simulation the results were not what i expected. When the resistance is increased there should be a voltage drop causing the voltage on the voltmeter (which is in series) to drop. No matter what value i give for the resistor I get the same 5V (which i used for the DC power supply).
Does anyone know why this is happening?
You'd have to give us a screenshot showing the circuit and the test points you applied.
- Warren
Below is the link to the circuit that i have
http://www.themodule.net/img/schem.gif
Your picture does not show the test points you applied, and is therefore incomplete.
- Warren
I just started to learn the program and I don't know how to put in those test points, could you help me with that? I tried searching for it in help but could not find anything relative.
microcap is also pretty good
I think that I have gotten what this testing thing is about, I used markers to show the voltage level as shown from my new circuit diagram:
http://www.themodule.net/img/circuit.gif
And I have setup a SPICE profile to do a DC sweep analysis, the thing is I still don't get a difference in the voltage. Today I even did over the lab at school.
Your circuit looks fine; one test point will always be at 5 V and the other will always be at 0 V.
If you want to do a DC sweep, you might have to use another kind of source, though -- try a VSRC.
No matter what source you use, however, the test points will show nothing but the battery potential and the ground potential.
- Warren
In my real experiment I have a voltmeter in series with the resistor and power supply. How do you think that I can achieve the objective of observing a change in the voltage since I cannot place a voltmeter in the circuit (I don't think that I can since I don't see one in any of the libraries)?
There should be a real voltmeter in one of the parts libraries. If you can't find one then you can place a 10M resistor in series with your test resistor and measure the voltages across the voltmeter and/or the test resistor.
Related to Program for designing simple circuits
1. What is a program for designing simple circuits?
A program for designing simple circuits is a computer software that allows users to create and simulate electronic circuits. It provides a user-friendly interface with drag-and-drop components and simulation capabilities to test the functionality of the circuit.
2. What are the benefits of using a program for designing simple circuits?
Using a program for designing simple circuits allows for faster and more efficient circuit design, as well as the ability to test and troubleshoot circuits before physically building them. It also allows for easy modifications and iterations of the circuit design.
3. Can I use a program for designing simple circuits without any prior knowledge?
Yes, most programs for designing simple circuits are designed to be user-friendly and do not require any prior knowledge or experience in circuit design. However, some basic understanding of electronic components and circuit theory can be helpful.
4. Are there any limitations to designing circuits using a program?
While programs for designing simple circuits are becoming more advanced, they may have limitations in terms of the types of circuits and components they can simulate. It is important to check the capabilities of the program before using it for complex or specialized circuits.
5. Can I use a program for designing simple circuits for professional purposes?
Yes, many professionals use programs for designing simple circuits as it allows for faster and more accurate circuit design. However, it is important to ensure that the program is reliable and can meet the specific needs of the project before using it for professional purposes.
  • Electrical Engineering
