What could be causing my program to abort on certain cases?
  • Thread starter Tom McCurdy
  • Tags
    Programming
In summary: Check; for (int j=0;j<bodyCopy.size();j++) { pleaseCheck = bodyCopy[j]; if (pleaseCheck=='.') { temp=bodyCopy.substr(0,j); pos1 = temp.find_last_of(" .,;:!?"); pos2 = temp.find_last_of(" "); temp = temp.substr(pos1+1,pos2-pos1); lowercase(temp); for (int kk=0; kk<searchTerms.size();kk++) { if (temp==searchTerms[kk]) { gate=1; break; }
Tom McCurdy
1,020
I wrote the following code: (well I wrote the markup function within it, the rest was written by my teacher)
Code:
// markup.cpp
// You must complete this program by properly implementing
// the routine called markup.  You can implement other routines
// to help markup do its work.
#include <iostream>
#include <fstream>
#include <string>
#include <cctype>
#include <cstdlib>
#include <cassert>
#include <vector>
using namespace std;
// The characters used to mark the opening and closing of tags,
// the name of the body tag and the body closing tag (in lower case),
// and the markup strings used.  Note that all of these are marked as
// constant so they cannot be changed by the executing algorithm.
// You do not need to use this, but are encouraged to use them, or
// something like them.
const char opentag ='<';
const char closetag ='>';
const string bodytag("body");
const string bodyclosetag("/body");
const string startMarkup("<B style=\"color:black;background-color:#A0FFFF\">");
const string endMarkup("</B>");
// Declarations of routines that are provided to you
void lowercase(string & s);
void printUsage(char * argv[]);
void parseInput(int argc, char * argv[], ifstream & in, ofstream & out,
                vector<string> & searchTerms);
void printSearchWords(const vector<string> & searchTerms);
// Declarations of the routine that you must complete
void markup(istream & in, ostream & out, const vector<string> & searchTerms);
// You should declare other routines that you use in implementing
// your markup routine
// ===>> main <<=====================================================
// main takes arguments from the command line, which represent
// the name of the code, the name of the inputfile, and a list of
// words to search for.  argc is the number of argumens provided, and
// argv is an array of c-strings that store the command line arguments
// Main is complete.  You do not need to change anything in main.
int main(int argc, char * argv[])
  // Make sure there are at least 3 words on the command line
  if(argc < 3) printUsage(argv);
  // Get the input and output streams, and the lowercase search words
  ifstream in;
  ofstream out;
  vector<string> searchTerms;
  parseInput(argc, argv, in, out, searchTerms);
  // printSearchWords(searchTerms);  // Used when testing parseInput
  // Students must write this routine (see below)
  markup(in, out, searchTerms);
  // Close the input and output streams
  in.close();
  out.close();
  return EXIT_SUCCESS;
// ===>> markup <<===================================================
// Read data from the in stream, find all of the words from the list
// of searchTerms, mark them bold on a cyan background, and write the
// marked up data to the outstream.  On entry the input stream will
// be ready for use and on the first character, the output stream
// will also be ready for use.  searchTerms will be a vector of words
// to search for; it will contain at least one word, and all the search
// words will be in lowercase.
    vector <string> theColors;
   theColors.push_back("F40500");
   theColors.push_back("9AFEF4");
   theColors.push_back("FECC30");
   theColors.push_back("6185FA");
   theColors.push_back("DE5D77");
   theColors.push_back("00FF00");
   theColors.push_back("CC00CC");
   theColors.push_back("FFCC00");
   theColors.push_back("99CCFF");
   theColors.push_back("CCCC99");
   theColors.push_back("CCFFCC");
   //vector <string>(F40500,9AFEF4,FECC30,6185FA,DE5D77);
   string content, bodyContent, front, middle, end, bodyCopy, final, theTop, theBottom;
   string eCode= "</B>";
   vector<string> bodyTemp;
   int gate=0, posStart,posMiddle, posEnd;
  // This routine does not do anything useful yet.
  // You will make it useful.  At present it just
  // copies the input stream to the output stream one
  // character at a time
  char c;
  c = in.get();  // get one character from the input
  while(not in.fail())
    content.push_back(c);
    //cout << c;
    // input succeded, so write the charcter to output
int pleaseStop = searchTerms.size();
for(int kk=0; kk<pleaseStop; kk++)
    string sCode("<B style=\"color:black;background-color:#");
   string s2Code=theColors[kk%11];
   string s3Code="\">";
    sCode= sCode+s2Code+s3Code;
  bodyContent=content;
  posStart = bodyContent.find("<body");
  bodyContent=bodyContent.erase( 0,posStart + 1);
  posMiddle = bodyContent.find(">");
  bodyContent=bodyContent.erase( 0,posMiddle + 1);
  posEnd = bodyContent.find("</body>");
  bodyContent = bodyContent.erase( posEnd,bodyContent.size() );
  theTop = content;
  theTop = theTop.erase( posStart+posMiddle+2, theTop.size());
  theBottom = content;
  int posBody = bodyContent.find("</body>");
  theBottom = "</body></html>";
  bodyCopy=bodyContent;
  int k=0;
  int inTag=0;
  char please;
  char periodHere='.';
  while(k < bodyCopy.size())
      bodyCopy[k] = tolower(bodyCopy[k]);
      please=bodyCopy[k];
      //cout<<please<<endl;
      if (please=='<')
           inTag=1;
      if (inTag==1)
           bodyCopy[k]=periodHere;
      if (please=='>')
           inTag=0;
      k = k + 1;
  //cout << endl << endl << bodyContent <<endl << endl<<bodyCopy<<endl;
  if (bodyCopy.npos == bodyCopy.find(searchTerms[kk]))
  final=bodyContent;
  while ( bodyCopy.npos != bodyCopy.find(searchTerms[kk]))
     int pos = bodyCopy.find(searchTerms[kk]);
     char x,y;
     if (pos != 0 && pos !=bodyCopy.size() )
     x=bodyCopy[pos-1];
     y=bodyCopy[pos + searchTerms[kk].size()];
     else if(pos==0)
          x=0;
          y=bodyCopy[pos+searchTerms[kk].size()];
     else
          y=0;
          x=bodyCopy[pos-1];
     front=front.erase();
    middle=middle.erase();
    end=end.erase();
     int j=0;
               while (j < pos)
                    front.push_back(bodyContent[j]);
                    j++;
               j=pos;
               while (j<pos+searchTerms[kk].size())
                    middle.push_back(bodyContent[j]);
                    j++;
               j=pos+searchTerms[kk].size();
               while (j<bodyContent.size())
                    end.push_back(bodyContent[j]);
                    j++;
      if ( (isalnum(x)==0) && (isalnum(y)==0) )
          final = final +  front + sCode + middle + eCode;
      else
          final = final + front + middle;
    bodyContent=bodyContent.erase( 0,pos + searchTerms[kk].size());
    bodyCopy=bodyCopy.erase( 0,pos + searchTerms[kk].size());
 //cout<<endl<<"theTop: "<<theTop<<endl;
 //cout<<endl<<"final: "<<final<<endl;
 //cout<<endl<<"end: "<<end<<endl;
 //cout<<endl<<"theBottom: "<<theBottom;
 final = theTop + final + end + theBottom;
  content=final;
  bodyContent=bodyContent.erase();
  end=end.erase();
  bodyCopy=bodyCopy.erase();
  final=final.erase();
  theTop=theTop.erase();
  theBottom=theBottom.erase();
//cout<<endl<<final;
out<<content;
// ===>> lowercase <<================================================
// Convert string to lowercase, in place
  unsigned int i = 0;
  while(i < s.size())
      s[i] = tolower(s[i]);
      i = i + 1;
// ===>> printUsage <<===============================================
// Print a usage message
  cerr << "Usage: " << argv[0] << " inputfile word1 [word2 word3 ... ]\n";
  exit(EXIT_FAILURE);
// ===>> parseInput <<===============================================
// Get the input file name, open the input and output files, and get
// the search words.  argc is the number of command line arguments,
// and argv is an array of those arguments as c-strings.  On exit in
// and out will be connected to files and ready for use, and
// searchTerms will be contain a list of strings containing words
// to search for, converted to lowercase letters.
// Requires that argc >= 3.
  // attach into the input file
  in.open(argv[1]);
  if(in.fail())
    cerr << "Input file " << argv[1] << " did not open\n";
    exit(EXIT_FAILURE);
  // attach out to the output file
  string outname = "marked";
  outname.append(argv[1]);
  out.open(outname.c_str());
  if(out.fail())
    cerr << "Output file " << outname << " did not open\n";
    exit(EXIT_FAILURE);
  // get the first search word and convert it to lowercase
  string s(argv[2]);
  lowercase(s);
  searchTerms.push_back(s);
  // get any additional search words and convert them to lowercase
  for(unsigned int i = 3; i < argc; i = i + 1)
    s = argv[i];
    lowercase(s);
// ===>> printSearchWords <<=========================================
// Print the words in searchTerms to standard output.  This was used
// for testing, but not in the final code.
  cout << "The search words are: \n";
  unsigned int i = 0;
  while(i < searchTerms.size())
      cout << "  " << searchTerms[i] << endl;
      i = i + 1;
and It works for most things, but I was trying to figure out while on some cases such as the boring.txt (please rename extention to .htm or .html if you test it) the program aborts. the program reads in a file then you give a vector of search terms and it finds them
  • boring.txt
Technology news on Phys.org
I guess you didn't notice that your previous programming question was moved to the "Programming" subforum of the "Computers" forum. :frown:
ww
Hey
Any Ideas?
1. What is programming help?
Programming help is assistance provided to individuals who are learning or working on programming languages or projects. It can range from simple tips and explanations to more in-depth guidance and troubleshooting.
2. Where can I find programming help?
There are various resources available for programming help, such as online tutorials, forums, and communities, coding bootcamps, and even hiring a personal tutor. It ultimately depends on your learning style and the level of support you need.
3. How can programming help improve my skills?
Programming help can provide you with a better understanding of programming concepts, techniques, and best practices. It can also help you identify and correct errors in your code, improve your problem-solving skills, and expand your knowledge of different programming languages and tools.
4. Can I get programming help for a specific language?
Yes, there are resources and experts available for almost every programming language. Some may specialize in one language, while others may have knowledge in multiple languages. It's essential to find the right help for the language you are working with to get the most effective assistance.
5. Is it okay to ask for programming help?
Asking for help is a crucial aspect of learning and growing as a programmer. It's normal to encounter challenges and need guidance, especially when starting. It's always better to seek help than struggle and potentially make mistakes that could be avoided with the right assistance.
