Homework Help: Programming Help
  1. Feb 15, 2012 #1
    Write a program to simulate rolling a six-sided “fair” die with one dot on one side, two dots on another side, three dots on another side, and so on. Allow the user to enter the number of rolls. Use first while loops to trap the illegal input number first (negative, zero, or float numbers). Use second loop to count the percentage distribution of each dot in the pay. Print the number of rolls that gave one dot, the number of rolls that gave two dots, and so on.
    What should be the percentage distribution of the number of dots from the rolls?
    2. Relevant condtions
    1) use rand function and ceil or floor function to generate a whole number between 1-6
    2) Use while loop and switch-case statement to count the times of each number in the play.
    3) Use fprintf to display the number of dots generated and the percent distribution of number of dots from the rolls.
    4) Trying to give a larger input number to loop more times. What should be the percentage distribution of each dot(s) on each side from the rolls?
    3. The attempt at a solution
    clc
    clear
    %User input
    user=input('How many times would you want to roll the dice ? :');
    %Error Statement
    while user <=0 || mod(user,2)~=0 || mod(user,2)~=1;
    disp('Error input,Please try again');
    end
    % Intilization
    counter=0;
    d1=0;
    d2=0;
    d3=0;
    d4=0;
    d5=0;
    d6=0;
    %To determine the number of dots
    while counter< user;
    count=round(rand*5+1)
    switch count
    case (1)
    d1=fprintf('The number of one dot is %2.f \n ',d1)
    percentage1=count/user*100
    percentage1=fprintf('The percentage of heads gotten is: %.2f \n' ,percentage1);
    case (2)
    d2=fprintf('The number of two dot is %2.f \n ',d2)
    percentage2=count/user*100
    percentage2=fprintf('The percentage of heads gotten is: %.2f \n' ,percentage2);
    case (3)
    d3=fprintf('The number of three dot is %2.f \n ',d3)
    percentage3=count/user*100
    percentage3=fprintf('The percentage of heads gotten is: %.2f \n' ,percentage3);
    case (4)
    d4=fprintf('The number of three dot is %2.f \n ',d4)
    percentage4=count/user*100
    percentage4=fprintf('The percentage of heads gotten is: %.2f \n' ,percentage4);
    case (5)
    d5=fprintf('The number of three dot is %2.f \n ',d5)
    percentage5=count/user*100
    percentage5=fprintf('The percentage of heads gotten is: %.2f \n' ,percentage5);
    otherwise
    d6=fprintf('The number of three dot is %2.f \n ',d6);
    percentage6=count/user*100
    end
    end
    Thank you for all the help
  3. Feb 16, 2012 #2
    This will not generate a fair die. The quantity rand*5+1 will produce a number in the range 1-6. It sounds like it would be fair, but rounding the number will produce the following results:
    1 (1 <= x < 1.5) - 10% of the time
    2 (1.5 <= x < 2.5) - 20% of the time
    3 (2.5 <= x < 3.5) - 20% of the time
    4 (3.5 <= x < 4.5) - 20% of the time
    5 (4.5 <= x < 5.5) - 20% of the time
    6 (5.5 <= x <= 6) - 10% of the time
    Instead, you could make it span 0.5-6.5 so that the rounding would create a fair die,
    count=round(rand*6+0.5)
    Edit: After rereading the question, I realized it said to use either the floor or ceil functions. It might be best to use one of those instead.
  4. Feb 16, 2012 #3
    clc
    clear
    %User input
    %Error Statement
    end
    % Intilization
    count=0;
    total_count=0;
    while total_count<= user;
    count=ceil(rand*5);
    total_count=count+1;
    switch count
    case (count==1)
    d1=fprintf('The number of one dot is %2.f \n ',d1);
    percentage1=count/user*100;
    case (count==2)
    d2=fprintf('The number of two dot is %2.f \n ',d2);
    percentage2=count/user*100;
    case (count==3)
    d3=fprintf('The number of three dot is %2.f \n ',d3);
    percentage3=count/user*100;
    case (count==4)
    d4=fprintf('The number of three dot is %2.f \n ',d4);
    percentage4=count/user*100;
    case (count==5)
    d5=fprintf('The number of three dot is %2.f \n ',d5);
    percentage5=count/user*100;
    otherwise
    percentage6=count/user*100;
    end
    end
    This is my new mathlab script after changes but it still does not work
  5. Feb 16, 2012 #4
    This still won't work. ceil(rand*5) will only produce integers 1-5.
    In your 2nd while loop, shouldn't that only be counting the number of times each die has rolled? It seems like your 2nd while loop encompasses much more than you want it to.
    In your program you set the counters d1-d6 to zero, yet you never incremented them. I think your code should be more along the lines of:
    Code (Text):
    count=ceil(rand*5);
    //increment the correct counter
    end
    //print out all of the averages
    Since I've never scripted anything in matlab, I can't comment on the syntax all the much.
  6. Feb 16, 2012 #5
    Thank you very much, I got it figured out.
