Homework Help: Progression, is monotonic?
  1. Oct 4, 2008 #1
    I got one progression [tex]\frac{2n-3}{3n-5}[/tex].
    Is this monotonic and convergent?
    2. Relevant equations
    3. The attempt at a solution
    I tried an-an+1=1/(3n-5)(3n-2)>0
    But for n=1 and n=2, we got 1/2 and 1, so I think that this string is not monotonic, right?
    I think it is convergent because it got a=2/3.
    [tex]|a_n-a|<\epsilon[/tex]
    Am I right?
  3. Oct 4, 2008 #2
    statdad
    Are you sure
    [tex]
    a_n - a_{n+1} = \frac 1 {(3n-5)(3n-2)}
    [/tex]
    is [tex] > 0 [/tex] for every [tex] n = 1, 2, 3, \dots [/tex]? :smile: Compare the result you
    get from the formula above to the actual value of [tex] a_1 - a_2 [/tex].
    You are on the correct track for proving convergence.
  4. Oct 4, 2008 #3
    tiny-tim
    Hi Physicsissuef! :smile:
    It would be much easier if you you rewrote it in the form 2/3 + A/(3n - 5). :wink:
    If it's monotonic except for the first one or two, then you should say so.
    It converges monotonically after a certain point. :smile:
  5. Oct 5, 2008 #4
    Yes, I am sure that it is correct, but as you can see for n=1 (i.e a1,a2), it is
    1/(3-5)(3-2)
    -1/2 < 0
    and for n>1, it is monotonic.
    So if I write
    [tex]|a_n-a|=|\frac{2n-3}{3n-5}-\frac{2}{3}|=|\frac{3(2n-3)-2(3n-5)}{3(3n-5)}|=
    |\frac{6n-9-6n+10}{3(3n-5}|=\frac{1}{3(3n-5)} < \epsilon[/tex]
    So it is convergent, probably for n>1, because if n=1, [tex]1/3(3-5)=-1/6 < \epsilon[/tex]
    Because of the fact that [tex]\epsilon[/tex] can't be negative i.e [tex]\epsilon > 0[/tex], it is convergent for n>1, right?
