Homework Help: Projectile Collision
  1. Mar 16, 2016 #1
    • Member advised to use the formatting template for questions posted to the homework forums
    A group of elderly, hospital-hating street toughs fire a mortar at a local children's hospital 960m away. The projectile has a muzzle speed of 100m/s and is directed 53.13 degrees above the horizontal. At the same instant, a contingent of concerned physics enthusiasts, knowing full well that children enjoy midair collisions, fire their own mortar at 36.87 degrees above the horizontal. The enthusiasts are 2.00 km away from the street toughs on the opposite side of the hospital, on a 50.0m high hilltop. a.) Find the initial velocity of the enthusiast's projectile if the hospital is to be saved. b.) Calculate the coordinates of the impact of the projectile. Note: use g = 10m/s^2 for the problem. Ignore the dimensions of the hospital.
    First I determined the time it took for the street tough's mortar to reach the hospital:
    960m = (V * cos53.13)t
    960m = (60 m/s)t
    t = 16s
    Then I tried to figure out what the intitial velocity for the enthusiast's mortar would have to be to travel 1040m (2000-960) in 16s and got:
    x=vt
    1040m=(v * cos36.87) *16s
    1040m = 12.8 * V
    81.25 = V
    I'm not sure what I'm doing wrong but I'm getting 81.25 m/s and the correct answer is
  3. Mar 16, 2016 #2
    mfb
    2017 Award
    Staff: Mentor
    If you calculate the vertical position of your interception projectile after 16 seconds, you'll see that it does not match the location of the hospital. It would hit the ground much earlier.
    The goal is not to hit the hospital at the same time. The goal is to hit the missile in flight before it hits the hospital. Both projectiles have to be at the same place at the same time. Preferably not directly at the hospital.
  4. Mar 16, 2016 #3
    I tried to set y1 (elderly) = y 2 (enthusiasts) and that didn't work either
    (v1*sinθ1)t - 1/2(gt2) = 50 + (v2*sinθ2)t - 1/2(gt2)
    100*sin53.13 = 50 + v2 * sin36.87
    30 = v2 * sin36.87
    50 = v2
  5. Mar 17, 2016 #4
    haruspex
    What happened to t?
  6. Mar 17, 2016 #5
    Wouldn't it cancel off of both sides? I don't know.
    I'm not good at this at all and I have a test in three hours. I don't know how to solve this problem and I really need to be pointed in the right direction for this if someone can please help.
  7. Mar 17, 2016 #6
    mfb
    2017 Award
    Staff: Mentor
    How? The 50 is not multiplied by t.
    If you do it correctly, you get a relation between v2 and t. The horizontal component gives you another relation. Two equations, two unknowns.
  8. Mar 17, 2016 #7
    So 30t=50+.6v2t?
    Not sure what to do with that
  9. Mar 17, 2016 #8
    haruspex
    Write the horizontal equation, as mfb suggests.
    Do you not know how to solve simultaneous equations? Standard procedure: if the two unknowns are x and y, and it's x that you want to find, write one equation in the form y=f(x) and use that to replace y in the other equation.
Have something to add?
Draft saved Draft deleted
