Projectile fired at 30º angle
  • Thread starter LittleWing
Determine how far away the projectile is from the launch point when it is 50m below the launch point. Determine the max height achieved by the projectile. What is the angle that the velocity vector makes with the horizontal at the point where the projectile is -50m from launch point. V=500 m/s @ 30º angle. What is distance in horizontal and angle of velocity vector when at -50m from launch.
v = u + at - Vf^2 - Vo^2 = 2aD
Having trouble starting this problem...
Answers and Replies
36
I am having a little trouble following what you wrote. If I am interpreting correctly. This is a projectile launched from an elevation with an initial velocity of 500 m/s, directed 30º above the horizontal. You are asked to calculate information about the projectile when it has dropped 50 m below the launch point (and gone some distance forward at the same time).
You can approach most two-dimensional motion problems by resolving vectors into perpendicular components. In this case that means taking the 500 m/s directed up at 30º and breaking it into a vertical component and a horizontal component. You can then solve for how long it takes the projectile to rise to its peak and fall to -50 m. That is the same time the projectile moves horizontally at a constant speed (since there are no forces acting on it in the horizontal direction).
well, you need to take into account the "speed" of gravity and how much it will slow the velocity down every second.
Putting the into in a graph will help, or even better... put the info in a graphics calculator and it will calculate the max hight ONLY!
for the horizontal direction, I'm not too sure?
@Fewmet- wouldn't gravity affect the horizontal speed because of the angles of the vectors?
36
No. I know that it seems, intuitively, like the downward pull of gravity makes something like a horizontally thrown ball speed up. What is increasing it the sum of the horizontal and vertical velocities.
Consider tossing a coin vertically while on a uniformly moving train. If gravity caused a horizontal acceleration, the coin would move forward faster than the train, than you and than your hand. It would land in front you on the train. The fact that it falls back into your hand is consistent with the principle that perpendicular vectors act independently of each other.
Related Threads on Projectile fired at 30º angle
  • Last Post
9K
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
