Uncovering the Best Angle for Projectile Motion: 30º vs. 45º Explained
In summary: I think your professor is wrong. The best angle for distance is not 45 degrees, it's actually 30 degrees. Air resistance affects projectiles the most when they are in the air, so the more distance you can shoot, the more air resistance you'll have to overcome.
reinaldo
33
Projectile motion!
Hey!...in college they teach you that the most efficient angle for projectile motion is the 45º, cause it gives you the farther distance...but when we did the experiment in the lab we obtain that the best angle (the most distance achived by the metal ball)...was 30º...the teacher said that it was not wrong...in fact...she said...you are shooting it at 30º and you`re getting more distance than with 45º...she asked us to explain why that could happend...
anyways...that happen 2 years ago...i did pass my 1st semester of Physics because with all the other exams and lab test...but she never wanted to explain why that happend!...she said that we should investigate ourselves...i have never got to know why...the only thing i could come up was that since i live in venezuela so I am technically in the middle of the world, it might have something to do with gravity or something like that...
so please...can anyone tell me why did that happened!...thanks!
two words... air resistance
A projectile travailing at 45 deg will lose more velocity over less ground covered then a projectile at 30 deg
Air Resistance??...but every Physics Book says that is the 45° angle that has the more distance shooting...Serway, Jones, Giambattista, Alan P Lightman, all those authors say that the 45° angle...so I am guessing that the 45° must be determine in northern latitudes or something...thats why i thought that maybe the fact that I am located in venezuela must have had something to do...microgravity, etc...
why all those authors obtain 45° while i got 30°??
Because most of those book don't take into account air resistance. or at least how it pulls it down to Earth over time. most of the books your talking about only use it to see how a bullet slows down over time but doesn't put it in with the angle calculation.
shooting in the north has little to no difference then the south.
what matters (and only in long range shooting... 1000yrds +) is the direction (with the rotation of the Earth or against it).
if you want a really good book to read. type "Understanding Fire Arm Ballistics" into ebay. this guy goes over every thing from barrel whip to how the grains of powder are formed...
Most physics textbooks when introducing the subject ignore the affect of air on moving objects for the sake of simplicity. I find it easier to first understand projectile motion in terms of pure theory, in a vacuum, as it describes will happen in %99.9999999 percent of the universe where there is no air. That way a solid theoretical foundation is formed it becomes even simpler to add on the obstructing concept of air resistance.
Hi reinaldo! :smile:
Some real physics!
Can you describe the experiment?
In particular, how did you launch the ball, and how did you make sure that it had the same speed at different angles?
And how far did it go, and did it land at the same height as it was launched from?
If the lab experiment was actually in a lab (ie, a small scale experiment), you really should have gotten an answer nearer to 45 degrees. The velocities would be too small for air resistance to make a difference. Could you describe the experiment?
Was it launched with a spring? When you launch with a spring, the initial velocities are not identical, since the spring has to absorb some of the weight of the ball. Ie, for a horizontal launch, f=ma, but for a vertical launch, f-mg=ma
I would hope your prof actually knew this and wasn't just blowing you off...
The experiment was made in a Lab with a Small Scale equipment and it consisted of a canon type shooter with a spring, you would lacht the spring and slide the metal ball inside, and the canon was place in an axis with a all the 90° posibles positions, then you would trigger the cannon at the selected angle and we´d measure the height obtain, and the distance obtain in the X axis...we repeated the experiment 15 times in each angle...15°, 23°, 30°, 37°, 45°, 55°, 70°, 80°...the most horizontal distance we got was with the 30° angle...
In that case, I'd suspect that the weight of the ball on the spring, resulting in an inconsistent launch speed, is what caused what you found.
Also, the optimum launch angle for distance when the projectile lands under its initial height is not 45 degrees, right?
While I agree with your point that it's simpler to ignore confounding factors such as air resistance until you've understood the basics, I think your rationale leaves something to be desired.
In 99.9999999% of the universe, you're not going to encounter gravitational forces that behave as planes (like they do on the human scale, on Earth, where gravity is a force whose direction never changes wrt the object's path). In 99.9999999% of the universe, forces of gravity will act more like points, and ballistic paths will be elliptical rather than parabolic.
1. What is projectile motion?
Projectile motion is the motion of any object that is thrown or launched into the air and has a curved path due to the effects of gravity.
2. What are the best angles for projectile motion?
The two most commonly used angles for projectile motion are 30 degrees and 45 degrees. These angles result in the furthest horizontal distance traveled for a given initial velocity and launch height.
3. How do you determine the best angle for projectile motion?
The best angle for projectile motion can be determined by finding the angle that results in the maximum horizontal distance traveled. This can be done through mathematical calculations or by experimenting with different angles and measuring the distance traveled.
4. Why are 30 and 45 degrees considered the best angles for projectile motion?
These angles are considered the best because they result in the furthest horizontal distance traveled while still maintaining a reasonable launch height. Additionally, they are easy angles to work with mathematically and are often used in real-world applications.
5. Are there any other factors besides angle that affect projectile motion?
Yes, there are other factors that can affect projectile motion, including initial velocity, air resistance, and launch height. These factors can all impact the trajectory and distance traveled of a projectile.
21K
12K
10K
