Projectile motion formula
  • Thread starter staka
I would like to simply know what Δy=[(sin2θ)(Vi)]^2/2a represents..
The formula only requires the angle and the initial velocity (along with the usual a=9.8m/s^2), so what height does the equation represent?
24
The distance a projectile travels (over flat ground) is [sin(2θ)*(v^2)]/a, very similar to what you have there. Is there a chace you misread it?
23
well that's the distance..
I think I got it now though, it's possibly the maximum height over a flat ground.
24
Oh yeah you're correct, i just googled it a bit and it came up. It is the maximum height you reach
Doc Al
Mentor
44,815
1,078
That's almost the formula for the maximum height of a trajectory. To correct it, replace sin2θ with sinθ.
So one of the famous equations for the motion of a projectile is as follows:
v2=u2+2as
v = final velocity
u = initial velocity
a = g = -9.8m/s2
s = distance travelled
Now, for a projectile being fired at an angle, the vertical component of velocity is usin%, where % is the angle between the ground and the direction of projection.
Rearrange your equation, with v=0 to get the maximum height attained by a projectile (note that in your equation, your v is my u).
You get:
s = u2/-2a = (usin%)2/-2a
As a = -9.8, you can ignore the minus sign and you basically have your equation (except for the sin2% bit).
Yes I don't know how to make greek alphabet symbols, so a % for an angle will do :D
Hope that helps.
Related Threads for: Projectile motion formula
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
