Projectile motion in kinematics
In summary, the first problem asks you to find the angle at which to fire your projectile in order to hit the enemy at the top of a hill. The second problem asks you to find the equation for a ball rolling down a set of stairs.
Lightening Lover
My physics prof. gave us the following "extra credit" problems dealing with projectiles, but there are two different ones, and therefor there will be two different color, lol but yeah here you go:
The first problem reads as following:
You are in the amry and unfortunately you are at a disadvangtage, for your enemy is on top of a hill 100 meters high, the center of the hill is 500 meters away. You have one projectiles which on it, the tag reads that it shoots at an initial velocity of 50meters/second. You have to find the angle at which you must fire the projectile, so that it travels up above the enemy's hill and comes straight dowm to hit the enemy.
Now there are 2 solutions to this problem, and I know that you need the higher one of the two, but I have no clue on how to solve it.
The second problem reads as following: You are rolling a ball down a set of stairs, your initial velocity is v m/s, the hieght of the stairs (or the riser) is y, the treads (or bases of the stairs) are x. The object of this problem is to find a formula that will have the variables v, y,x,(as defined earlier), n(the number of steps) and a (gravitational pull aka 9.81). You must have it in the fashion ofn=the equation. However the only catch is that the equation must deliver whole numbers.
For this one I know how to get the whole numbers however, I don't know the equation.
Any help at all on either problems would be greatly appreciated
Only 5 meters per second?
Doug
You will have 2 answers for the first problem - one will be on the way up and one on the way down - if the projectile will reach, then you will use the later of the two - if not, your army is screwed.
Nautica
fixing mistakes
for the first reply, no I'm sorry it is 50m/s not 5m/s, sry about that, I changed it now though.
And for the second reply, that is not correct, because the shape that the projectile would take is a parabola, and if you look below at the diagrames you can see that there are two possible ways to hit the hill(btw sry about the diagram, can't do anything on my computer right)
***** __**********************imagine that the lines are curves
*****/**\********************and you are at x, and the enemy at e
****/****\******************and the stars are spaces
***/*****e********OR**********_'e
**/*****/*\******************_'*/*\
*/*****/**\****************_'**/***\
x'****/****\************x'****/*****\
this diagram shows/////while this one shows
how the projectile/////that the projectile
would first go up//////would hit the enemy
and then com down//////from the side
to hit the enemy///////(or before the
(or after the////////// turning point)
turning point)
What is projectile motion?
Projectile motion refers to the motion of an object that is launched or thrown and then continues to move under the influence of gravity alone. Examples of projectiles include a ball thrown in the air, a bullet fired from a gun, or a rocket launched into space.
What are the key components of projectile motion?
The key components of projectile motion are the initial velocity, the angle of launch, and the acceleration due to gravity. These factors determine the path of the projectile and how far it will travel.
How does the angle of launch affect projectile motion?
The angle of launch has a significant impact on projectile motion. As the angle increases, the horizontal component of the initial velocity increases, resulting in a longer horizontal distance traveled. However, the vertical component decreases, resulting in a lower maximum height reached.
How does air resistance affect projectile motion?
Air resistance can affect projectile motion by slowing down the object and changing its trajectory. This is particularly significant for objects with a large surface area, such as a feather, as they experience more air resistance than smaller, more streamlined objects.
What is the difference between range and maximum height in projectile motion?
The range refers to the horizontal distance traveled by a projectile, while the maximum height refers to the highest point reached by the projectile. These values are affected by factors such as the initial velocity, angle of launch, and acceleration due to gravity.
21K
