1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Projectile Motion Problems
  1. Nov 24, 2008 #1
    An athlete executing a long jump leaves the ground at a 20° angle and travels 7.80 m.
    (a) What was the takeoff speed?
    2. Relevant equations
    Trigonometry- 3.6tan(20)=1.42 which is the max height
    Vy² = Vyo² + 2a(y-yo) to find initial velocity
    Vy = Vyo + at to find time
    x = xo + Vxot + 1/2at² to find velocity initial
    3. The attempt at a solution
    3.6tan(20)=1.4194839136381892092690867428297m is the meters for max height.
    Vy² = Vyo² + 2(-9.8m/s²)(1.4194839136381892092690867428297)
    Vyo² = 27.821884707308508501674100159461m/s
    Vyo = 5.2746454579723657955166904897785m/s
    Vy = 5.2746454579723657955166904897785m/s + (-9.8m/s)t
    t = 0.53822912836452712199149902956923s
    0.53822912836452712199149902956923s x 2 = 1.0764582567290542439829980591385s for total hang time
    7.8m = 0m + Vxo1.0764582567290542439829980591385s + 1/2(0m/s²)(1.07646)²
    Vxo = 7.2459846457039799434766682275793
    This is not the correct answer, or so I'm told. I also tried twice the velocity for 14.491969291407959886953336455159 but it is still incorrect.
    I know it is something similar to this because there is another part, "(b) If this speed were increased by just 6.0 percent, how much longer would the jump be? "
    For this the answer resulted to be 0.96407999999999999999999999998m, which is correct. I think this means that I am on the right track, but need to put the correct number choice. Any inputs on possible numbers would be appreciated.
    edit:I was told of another number that could be possible, 10.9, but I don't know how this number was reached, or if it is correct. Just thought I'd put it out
  3. Nov 24, 2008 #2
    I'm not sure how you got this equation - 3.6tan(20)=1.42 but it's wrong
    The max height is given by Sy=(u2sin220)/2g, this is derived from the equation Vy² = Vy0² - 2gSy and letting Vy be zero.
    For maximum range you should use the equation, R=(u2sin(40)/g), this is derived using S=V0t+0.5at2 for both the x and y directions, then letting Sy be zero and eliminating t from the equations.
  4. Nov 24, 2008 #3
    I am not clear on what the "Sy=(u2sin220)/2g" equation is. I have never seen this before, nor do I understand what the S and the u and maybe the g represents.
    Also I forgot clarify that the 3.6 is half of the total distance.
    3.6tan(20) is supposed to be the meters upwards that would have been jumped, according to trigonometry. Thinking back, I think this part might be wrong, but it did, more or less, lead to a possible answer.
    The 3.6 represents the distance the jumper reaches before he reaches his max height. Later the time is multiplied by 2 to account the fact that 3.6 is only half the total jump/distance/time.
    edit: I tried with 7.8, and without multiplying the time by two. This got me, 10.247369758701774468445911215078 m/s. This might have something to do with the 10.9 I wrote in the edit of the opening post, and might of been rounded to result in 10.9.
  5. Nov 24, 2008 #4
    I'm using S to denote the displacement of the object and u to denote the initial velocity of the object, g is the acceleration due to gravity(ie. 9.81) and R is the maximum range which is 7.8 is this case.
    Using 3.6tan(20) to denote the maximum height is wrong as you are assuming that the person is jumping in a triangle motion, but it's actually projectile motion which is a curved path.
  6. Nov 24, 2008 #5
    I see. I didn't understand your equations because I am being taught using a less proper way. Pardon my ignorance.
    Aside from that, with the R=(u²sin(40)/g), I seems to have gotten the right answer.
    Doing 7.8 = (u²sin(40)/9.8) gets me u = 10.905023123552279645808268515182m/s. This seems correct. I will be checking it later. Thank you.
  7. Nov 24, 2008 #6
    Since the 10.9 seems correct, I now run into a new problem.
    "If this speed were increased by just 6.0 percent, how much longer would the jump be?"
    My previous method to attain the correct answer worked, but it worked under an incorrect velocity. It might have something to do with the way I played with the numbers but it won't work with the correct velocity.
    What I would normally do, if I had not achieved the answer for the increased speed, but had the velocity:
    10.9m/s×1.06 = 11.56m/s
    With this I used trigonometry to find the time:
    11.56tan(20) = 4.2m/s
    (4.2m/s)/(9.8m/s²) = 0.43s
    With this I would multiply by two to find the total hang time and then multiple with the velocity x.
    0.43s×2 = 0.86s
    0.86s×11.56m/s = 9.925m.
    9.925m-7.8m does not equal the number that would be correct, which is 0.964m, or something similar.
    Where does this go wrong, that is, if it is even right at all.
    The full format/numbers:
    10.905023123552279645808268515182m/s×1.06 = 11.559324510965416424556764626093m/s
    11.559324510965416424556764626093tan(20) = 4.2072500502151376623954096047118m/s
    (4.2072500502151376623954096047118m/s)/(9.8m/s²) = 0.42931122961378955738728669435827s
    0.42931122961378955738728669435827s×2 = 0.85862245922757911477457338871653s
    0.85862245922757911477457338871653s×11.559324510965416424556764626093m/s = 9.9250956386147591540094551406057m.
    9.9250956386147591540094551406057m-7.8m does not equal the number that would be correct, which is 0.96407999999999999999999999998m, or something similar.
  8. Nov 24, 2008 #7
    Try using back the equation R=(u²sin(40)/g), notice that the maximum distance is directly proportion to u2, hence when the velocity is changed to 1.06 times, R will become 1.062 times.
  9. Nov 24, 2008 #8
    Ah thanks. I see know. Okay then I guess that wraps up everything. Only thing left is to fully understand those equations and fit it to the ones I learned. That is all.
Similar Discussions: Projectile Motion Problems
Loading...
