Sarah00
- 64
- 1
I know that the acceleration is downward always with value of 10m/s2
The answer is D? because j denote vertical axis and negative sign means downward?
[/B]
Yes.Sarah00 said:Homework Statement
The answer is D? because j denote vertical axis and negative sign means downward?[/B]
Projectile motion is the motion of an object through the air, typically following a curved path due to the influence of gravity. This type of motion is commonly seen in objects such as baseballs, projectiles, and even planets in orbit.
The two main factors that affect projectile motion are the initial velocity of the object and the force of gravity. Other factors that can play a role include air resistance, wind, and the shape and size of the object.
To calculate the trajectory of a projectile, you need to use vector quantities such as velocity, acceleration, and displacement. By breaking down the motion into x and y components, you can use equations of motion and vector addition to determine the path of the projectile.
Scalar quantities are those that have only magnitude, such as speed or temperature. Vector quantities have both magnitude and direction, such as velocity or force. In projectile motion, quantities such as displacement and acceleration are considered vectors.
Projectile motion is used in many real-life applications, including sports such as baseball and basketball, where players must calculate the trajectory of their throws. It is also used in engineering, such as in ballistics and in designing roller coasters.
